Salta al contenuto principale
HP 15-R263DX Keyboard Replacement
Cosa ti serve
    1. HP 15-R263DX Keyboard Replacement, Battery: passo 1, immagine 1 di 2 HP 15-R263DX Keyboard Replacement, Battery: passo 1, immagine 2 di 2
      • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
      • Slide the battery out as shown in the picture.
      Chiedi a FixBot
      Aggiungi Commento
    1. HP 15-R263DX Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
      • Once keyboard is loose, do not immediately remove it from the computer. It is attached by a ribbon connector.
      • Using a metal wedge tool, pry up along the top edge of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP 15-R263DX Keyboard Replacement: passo 3, immagine 1 di 1
      • To disconnect the ribbon connector, flip up the black clip shown in the picture.
      • Gently pull the ribbon until disconnected.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 689
