Salta al contenuto principale
HP 15-R011DX RAM (Random Access Memory) Replacement
Cosa ti serve
  1. HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: passo 1, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the lock mechanism on the left side of the laptop to the right.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 2, immagine 1 di 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: passo 3, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: passo 3, immagine 2 di 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 4, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 4, immagine 2 di 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 5, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 5, immagine 2 di 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 6, immagine 1 di 3 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 6, immagine 2 di 3 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 6, immagine 3 di 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 7, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 7, immagine 2 di 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP 15-R011DX RAM (Random Access Memory) Replacement, Hard Drive: passo 8, immagine 1 di 1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
    Chiedi a FixBot
    Aggiungi Commento
  9. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 9, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 9, immagine 2 di 2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
    Chiedi a FixBot
    Aggiungi Commento
  10. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 10, immagine 1 di 1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
    Chiedi a FixBot
    Aggiungi Commento
  11. HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: passo 11, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: passo 11, immagine 2 di 2
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  12. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 12, immagine 1 di 1
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  13. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 13, immagine 1 di 1
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  14. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 14, immagine 1 di 1
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  15. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 15, immagine 1 di 1
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
    Chiedi a FixBot
    Aggiungi Commento
  16. HP 15-R011DX RAM (Random Access Memory) Replacement, RAM (Random Access Memory): passo 16, immagine 1 di 1
    • Locate the RAM drive on the underside of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  17. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 17, immagine 1 di 2 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 17, immagine 2 di 2
    • Push the locking tabs outward to release the RAM chip from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  18. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 18, immagine 1 di 1
    • Remove the RAM chip by pulling the drive from the connectors.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 21
Tutti i Tempi: 1,418
