Introduzione
If you are considering replacing your RAM on your HP 14-cf2112wm due to booting issues, try troubleshooting it with this guide first.
When buying new RAM, you have to consider the frequency, voltage, latency, capacity, and warranty of the RAM.
For this HP 14. you can technically buy a a 16 GB RAM to replace it, but the hard drive might not be able to hold it.
Before you begin this repair, be sure to power off your laptop and unplug it from the charger.
Cosa ti serve
Place your opened laptop on a flat surface.
Use a Phillips #1 screwdriver to remove the four Phillips 3.0 mm screws securing the battery.
Pull the metal arms (located on both sides of the RAM stick) slightly away from it .
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
