Salta al contenuto principale
Google Pixel C Screen Replacement
Cosa ti serve
  1. Google Pixel C Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel C Screen Replacement: passo 2, immagine 1 di 2 Google Pixel C Screen Replacement: passo 2, immagine 2 di 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel C Screen Replacement: passo 3, immagine 1 di 2 Google Pixel C Screen Replacement: passo 3, immagine 2 di 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel C Screen Replacement: passo 4, immagine 1 di 2 Google Pixel C Screen Replacement: passo 4, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team S21-G4, Livingston Spring 2017 Membro di Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Membri
11 guide realizzate
28Commenti sulla guida
Where can a replacement screen be located?
Ronnie Williams - Rispondi Condividi
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Rispondi Condividi
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Rispondi Condividi
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - Rispondi Condividi
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 17
Ultimi 30 giorni: 98
Tutti i Tempi: 19,547
