Salta al contenuto principale
Google Pixel C Power Button Replacement
Cosa ti serve
  1. Google Pixel C Power Button Replacement, Screen: passo 1, immagine 1 di 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel C Power Button Replacement: passo 2, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 2, immagine 2 di 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel C Power Button Replacement: passo 3, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 3, immagine 2 di 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel C Power Button Replacement: passo 4, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 4, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel C Power Button Replacement, Power Button: passo 5, immagine 1 di 1
    • Locate the power button along the edge of the tablet.
    • The actual power button technology is the black plastic piece located directly inside the device behind the silver button; this is what will be replaced.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel C Power Button Replacement: passo 6, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 6, immagine 2 di 2
    • Locate and remove the black 4.3mm Phillips #000 screw.
    • Remove the remaining two silver 4.2mm Phillips #000 screws.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel C Power Button Replacement: passo 7, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 7, immagine 2 di 2
    • Use tweezers to slowly pull up on the power button technology as far as possible without pulling out the two black wires attached.
    • Don't pull up too hard, as the wires could be ripped out and damaged.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel C Power Button Replacement: passo 8, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 8, immagine 2 di 2
    • Detach the larger connector wire by flipping the copper hinge located at the base of the connection with your fingernail.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel C Power Button Replacement: passo 9, immagine 1 di 1
    • Flip the hinge of the second, more narrow wire to release the connection.
    • Don't pull the power button technology out yet. This wire is attached at one more place in the device.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel C Power Button Replacement: passo 10, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 10, immagine 2 di 2
    • Locate and remove the three 4.2mm Phillips #000 screws at the base of where the second wire is still connected.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel C Power Button Replacement: passo 11, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 11, immagine 2 di 2
    • Once all the screws are removed, gently pull up on the entire power button technology piece, to remove it from the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
Cal Poly, Team S21-G4, Livingston Spring 2017 Membro di Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Membri
11 guide realizzate
1Commento della guida
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
Colleen Price - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 55
Tutti i Tempi: 3,112
