Introduzione
This repair guide was authored by a member of the iFixit community and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the NFC antenna in a Google Pixel 2 XL.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
Press firmly to eject the tray.
Passo 3 Opening Procedure
Attenzione: i passaggi 3-14 provengono da una guida contrassegnata come in corso.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
Use the flat end of a spudger to disconnect the battery connector.
Use the point of a spudger to disconnect the front-facing camera connector.
Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
Remove the motherboard.
Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
Passo 25 Back Glass
Attenzione: il passaggio 25 proviene da una guida contrassegnata come in corso.
Apply plenty of heat to the right side of the back glass.
Use a small suction cup and pull the glass up to put an opening pick under it.
If you do not have a suction cup, you can try to fit a jimmy underneath the glass. You will likely damage the enamel using this method.
Keep applying heat and slowly moving the opening picks around the top of the phone.
Apply gentle heat to the NFC antenna contact and detach it from the frame.
Apply gentle heat to the NFC antenna and peel it off of the frame.
