Introduzione
This is an outdated guide, go here for the newest version.
Use this guide to remove or replace the motherboard in a Google Pixel 2 XL.
Cosa ti serve
Passo 1 Opening Procedure
Attenzione: i passaggi 1-12 provengono da una guida contrassegnata come in corso.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
Use the flat end of a spudger to disconnect the battery connector.
Insert a paperclip or SIM eject tool into the small hole on the left side of the phone and push until the SIM card tray pops out.
Remove the SIM card tray.
