Salta al contenuto principale
GoPro Hero4 Silver Image Sensor Replacement
Cosa ti serve
    1. GoPro Hero4 Silver Image Sensor Replacement, Front Panel: passo 1, immagine 1 di 3 GoPro Hero4 Silver Image Sensor Replacement, Front Panel: passo 1, immagine 2 di 3 GoPro Hero4 Silver Image Sensor Replacement, Front Panel: passo 1, immagine 3 di 3
      • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
      • The seven plastic tab locations are marked in red.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
      • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
      Chiedi a FixBot
      Aggiungi Commento
    1. GoPro Hero4 Silver Image Sensor Replacement, Image Sensor: passo 2, immagine 1 di 1
      • Remove the three 8 mm Phillips #000 screws on each corner of the camera.
      • Remove the single 4 mm Phillips #000 screw on the bottom left corner of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    2. GoPro Hero4 Silver Image Sensor Replacement: passo 3, immagine 1 di 2 GoPro Hero4 Silver Image Sensor Replacement: passo 3, immagine 2 di 2
      • To remove the motherboard assembly from the camera casing, use the plastic opening tool on the lens side of the camera to pry the motherboard assembly out of the camera housing.
      • To avoid breaking the plastic on the lens side of the camera (see photo), pry along the edges near the corners.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the motherboard assembly open, but found that it did not give us enough leverage.
      • Do not try to pry near the power button side of the camera. This will break important cables inside.
      Chiedi a FixBot
      Aggiungi Commento
    3. GoPro Hero4 Silver Image Sensor Replacement: passo 4, immagine 1 di 2 GoPro Hero4 Silver Image Sensor Replacement: passo 4, immagine 2 di 2
      • Remove the four 8 mm Phillips #000 screws securing the camera sensor assembly.
      Chiedi a FixBot
      Aggiungi Commento
    4. GoPro Hero4 Silver Image Sensor Replacement: passo 5, immagine 1 di 3 GoPro Hero4 Silver Image Sensor Replacement: passo 5, immagine 2 di 3 GoPro Hero4 Silver Image Sensor Replacement: passo 5, immagine 3 di 3
      • To remove the sensor assembly, simply peel off the lens towards the attached ribbon cable.
      • The sensor has ribbon cables running to the motherboard via a black rectangular connector.
      • To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
      • With the old camera sensor assembly removed, you can now replace it with a new sensor.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
USF Tampa, Team 2-1, Blackwell Fall 2015 Membro di USF Tampa, Team 2-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G1
4 Membri
20 guide realizzate
3Commenti sulla guida
Did GoPro make an updated version of the sensor, or are all the ones sold on the web just the same as the one that keeps failing in the cameras? Do you have a part number for the sensor that is supposed to work better? No point replacing the sensor with the same one the camera came with as it will likely fail withing a year just like the original one. Please advice.
David Kvick - Rispondi Condividi
thanks for the instructions - easy to understand and carry out. my GoPro 4 is now up and running again
Nigel Jones - Rispondi Condividi
Pregunta el sensor de la go pro hero 4 black es el mismo de la gopro hero 4 silver???
Jacinto - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 51
Tutti i Tempi: 15,038
