Salta al contenuto principale
GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement
Cosa ti serve
  1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: passo 1, immagine 1 di 2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    Chiedi a FixBot
    Aggiungi Commento
  2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 2, immagine 1 di 2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
    Chiedi a FixBot
    Aggiungi Commento
  3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 3, immagine 1 di 2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 3, immagine 2 di 2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    Chiedi a FixBot
    Aggiungi Commento
  4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Battery: passo 4, immagine 1 di 1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
    Chiedi a FixBot
    Aggiungi Commento
  5. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 5, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Using tweezers, peel off the copper tape on the right side of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  6. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 6, immagine 1 di 2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 6, immagine 2 di 2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
    Chiedi a FixBot
    Aggiungi Commento
  7. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 7, immagine 1 di 1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    Chiedi a FixBot
    Aggiungi Commento
  8. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 1 di 3 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 2 di 3 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 3 di 3
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
    Chiedi a FixBot
    Aggiungi Commento
  9. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 9, immagine 1 di 1
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
    Chiedi a FixBot
    Aggiungi Commento
  10. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 10, immagine 1 di 1
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
    Chiedi a FixBot
    Aggiungi Commento
  11. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 11, immagine 1 di 1
    • Gently lift the microSD/Micro USB assembly up and out of the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro di USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membri
20 guide realizzate
2Commenti sulla guida
Hi were can i buy the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Hector - Rispondi Condividi
Very helpful guide
Ninigo Marine Contractor - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 60
Tutti i Tempi: 4,218
