Salta al contenuto principale
GoPro Hero+ LCD Battery Replacement
Cosa ti serve
  1. GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    Chiedi a FixBot
    Aggiungi Commento
  2. GoPro Hero+ LCD Battery Replacement: passo 2, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
    Chiedi a FixBot
    Aggiungi Commento
  3. GoPro Hero+ LCD Battery Replacement: passo 3, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement: passo 3, immagine 2 di 2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    Chiedi a FixBot
    Aggiungi Commento
  4. GoPro Hero+ LCD Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
    Chiedi a FixBot
    Aggiungi Commento
  5. GoPro Hero+ LCD Battery Replacement: passo 5, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Using tweezers, peel off the copper tape on the right side of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  6. GoPro Hero+ LCD Battery Replacement: passo 6, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement: passo 6, immagine 2 di 2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
    Chiedi a FixBot
    Aggiungi Commento
  7. GoPro Hero+ LCD Battery Replacement: passo 7, immagine 1 di 1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 19 persone hanno completato questa guida.
Kyle
Membro da: 08/27/15
219 Reputazione
Una guida realizzata
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro di USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membri
20 guide realizzate
13Commenti sulla guida
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - Rispondi Condividi
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård - Rispondi Condividi
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - Rispondi Condividi
not even amazon?
Mary D'Alesandro - Rispondi Condividi
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 44
Ultimi 7 giorni: 79
Ultimi 30 giorni: 227
Tutti i Tempi: 42,288
