Salta al contenuto principale
Giant Reign 2 Tube Replacement
Cosa ti serve
  1. Giant Reign 2 Tube Replacement, Hex Screws: passo 1, immagine 1 di 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
    Chiedi a FixBot
    Aggiungi Commento
  2. Giant Reign 2 Tube Replacement, Axle Screw: passo 2, immagine 1 di 2 Giant Reign 2 Tube Replacement, Axle Screw: passo 2, immagine 2 di 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
    Chiedi a FixBot
    Aggiungi Commento
  3. Giant Reign 2 Tube Replacement: passo 3, immagine 1 di 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
    Chiedi a FixBot
    Aggiungi Commento
  4. Giant Reign 2 Tube Replacement, Front Wheel: passo 4, immagine 1 di 1
    • Pull the wheel from the fork.
    Chiedi a FixBot
    Aggiungi Commento
  5. Giant Reign 2 Tube Replacement, Tube: passo 5, immagine 1 di 1
    • Look at your tire and determine the correct tube size by locating the number (formated ## x #.##) on the wall of the tire.
    • Bike tubes come with one of two standard valve types: presta and schrader. These guides show the installation of a tube with a presta valve.
    Chiedi a FixBot
    Aggiungi Commento
  6. Giant Reign 2 Tube Replacement: passo 6, immagine 1 di 3 Giant Reign 2 Tube Replacement: passo 6, immagine 2 di 3 Giant Reign 2 Tube Replacement: passo 6, immagine 3 di 3
    • Unscrew the cap covering the valve.
    • Remove the spacer that holds the valve in place against the rim of the wheel.
    • Open the valve by turning the nut and pressing the valve in to release air pressure from the tube.
    Chiedi a FixBot
    Aggiungi Commento
  7. Giant Reign 2 Tube Replacement: passo 7, immagine 1 di 3 Giant Reign 2 Tube Replacement: passo 7, immagine 2 di 3 Giant Reign 2 Tube Replacement: passo 7, immagine 3 di 3
    • Slide the tire lever between the tire and the rim.
    • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
    • Insert a second tire lever adjacent to the first.
    • Slowly work one tire lever around the rim until the whole tire is loose.
    Chiedi a FixBot
    Aggiungi Commento
  8. Giant Reign 2 Tube Replacement: passo 8, immagine 1 di 2 Giant Reign 2 Tube Replacement: passo 8, immagine 2 di 2
    • Press the valve through the rim of the wheel.
    • Remove the tube from the tire.
    Chiedi a FixBot
    Aggiungi Commento
  9. Giant Reign 2 Tube Replacement: passo 9, immagine 1 di 1
    • Partially inflate the tube.
    Chiedi a FixBot
    Aggiungi Commento
  10. Giant Reign 2 Tube Replacement: passo 10, immagine 1 di 2 Giant Reign 2 Tube Replacement: passo 10, immagine 2 di 2
    • Push the valve through the rim.
    • Push the tube into the tire all the way around the rim of the wheel.
    Chiedi a FixBot
    Aggiungi Commento
  11. Giant Reign 2 Tube Replacement: passo 11, immagine 1 di 1
    • Push the bead of the tire back into place around the rim.
    • Make sure not to pinch the tube between the bead of the tire and the rim. Failure to do so may cause a pinch flat.
    Chiedi a FixBot
    Aggiungi Commento
  12. Giant Reign 2 Tube Replacement: passo 12, immagine 1 di 1
    • Inflate the tube to the desired air pressure.
    • A suggested range of air pressure is located on the wall of the tire (formatted ##-##psi).
    Chiedi a FixBot
    Aggiungi Commento
  13. Giant Reign 2 Tube Replacement: passo 13, immagine 1 di 2 Giant Reign 2 Tube Replacement: passo 13, immagine 2 di 2
    • Close the valve and replace the cap.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Cal Poly, Team 9-14, Amido Fall 2012 Membro di Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 55
Tutti i Tempi: 3,503
