Salta al contenuto principale
Giant Reign 2 Headset Replacement
Cosa ti serve
  1. Giant Reign 2 Headset Replacement, Hex Screws: passo 1, immagine 1 di 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
    Chiedi a FixBot
    Aggiungi Commento
  2. Giant Reign 2 Headset Replacement, Axle Screw: passo 2, immagine 1 di 2 Giant Reign 2 Headset Replacement, Axle Screw: passo 2, immagine 2 di 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
    Chiedi a FixBot
    Aggiungi Commento
  3. Giant Reign 2 Headset Replacement: passo 3, immagine 1 di 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
    Chiedi a FixBot
    Aggiungi Commento
  4. Giant Reign 2 Headset Replacement, Front Wheel: passo 4, immagine 1 di 1
    • Pull the wheel from the fork.
    Chiedi a FixBot
    Aggiungi Commento
  5. Giant Reign 2 Headset Replacement, Headset: passo 5, immagine 1 di 2 Giant Reign 2 Headset Replacement, Headset: passo 5, immagine 2 di 2
    • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
    • If necessary use wire cutters to release zip ties attaching cables to the forks.
    Chiedi a FixBot
    Aggiungi Commento
  6. Giant Reign 2 Headset Replacement: passo 6, immagine 1 di 3 Giant Reign 2 Headset Replacement: passo 6, immagine 2 di 3 Giant Reign 2 Headset Replacement: passo 6, immagine 3 di 3
    • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
    • Using the 4mm Allen wrench, loosen the side screw on both sides.
    • Lift off the handlebar.
    • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
    Chiedi a FixBot
    Aggiungi Commento
  7. Giant Reign 2 Headset Replacement: passo 7, immagine 1 di 3 Giant Reign 2 Headset Replacement: passo 7, immagine 2 di 3 Giant Reign 2 Headset Replacement: passo 7, immagine 3 di 3
    • Slide off the spacers.
    • Lift off the seal.
    Chiedi a FixBot
    Aggiungi Commento
  8. Giant Reign 2 Headset Replacement: passo 8, immagine 1 di 1
    • Slide the fork out of the casing.
    Chiedi a FixBot
    Aggiungi Commento
  9. Giant Reign 2 Headset Replacement: passo 9, immagine 1 di 1
    • Using your fingers, pry the bearings from the top and bottom of the headset.
    Chiedi a FixBot
    Aggiungi Commento
  10. Giant Reign 2 Headset Replacement: passo 10, immagine 1 di 1
    • Apply WD-40 to both ends of the headset and bearings.
    • Dry headset and bearings with paper towels.
    • Repeat as necessary until clean.
    Chiedi a FixBot
    Aggiungi Commento
  11. Giant Reign 2 Headset Replacement: passo 11, immagine 1 di 2 Giant Reign 2 Headset Replacement: passo 11, immagine 2 di 2
    • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
    • Insert the bearings into the headset with the beveled side facing into the headset.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 9-14, Amido Fall 2012 Membro di Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 40
Tutti i Tempi: 4,654
