Salta al contenuto principale
General Electric Create Jason Wu Lens Replacement
Cosa ti serve
  1. General Electric Create Jason Wu Lens Replacement, General Electric Create Jason Wu Casing Disassembly: passo 1, immagine 1 di 3 General Electric Create Jason Wu Lens Replacement, General Electric Create Jason Wu Casing Disassembly: passo 1, immagine 2 di 3 General Electric Create Jason Wu Lens Replacement, General Electric Create Jason Wu Casing Disassembly: passo 1, immagine 3 di 3
    • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
    • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
    • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
    Chiedi a FixBot
    Aggiungi Commento
  2. General Electric Create Jason Wu Lens Replacement: passo 2, immagine 1 di 2 General Electric Create Jason Wu Lens Replacement: passo 2, immagine 2 di 2
    • After the screws are removed, pull the front casing up and away from the camera.
    • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
    Chiedi a FixBot
    Aggiungi Commento
  3. General Electric Create Jason Wu Lens Replacement: passo 3, immagine 1 di 3 General Electric Create Jason Wu Lens Replacement: passo 3, immagine 2 di 3 General Electric Create Jason Wu Lens Replacement: passo 3, immagine 3 di 3
    • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
    • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
    Chiedi a FixBot
    Aggiungi Commento
  4. General Electric Create Jason Wu Lens Replacement: passo 4, immagine 1 di 3 General Electric Create Jason Wu Lens Replacement: passo 4, immagine 2 di 3 General Electric Create Jason Wu Lens Replacement: passo 4, immagine 3 di 3
    • The last part of the casing to disconnect is the back that houses the LCD screen.
    • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
    • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
    • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
    Chiedi a FixBot
    Aggiungi Commento
  5. General Electric Create Jason Wu Lens Replacement, General Electric Create Jason Wu Interior Disassembly: passo 5, immagine 1 di 3 General Electric Create Jason Wu Lens Replacement, General Electric Create Jason Wu Interior Disassembly: passo 5, immagine 2 di 3 General Electric Create Jason Wu Lens Replacement, General Electric Create Jason Wu Interior Disassembly: passo 5, immagine 3 di 3
    • After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
    • The pad isn't secured to the camera so it will lift up and pull away easily.
    • After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
    Chiedi a FixBot
    Aggiungi Commento
  6. General Electric Create Jason Wu Lens Replacement: passo 6, immagine 1 di 3 General Electric Create Jason Wu Lens Replacement: passo 6, immagine 2 di 3 General Electric Create Jason Wu Lens Replacement: passo 6, immagine 3 di 3
    • Using the Phillips precision screwdriver with the PH000 Phillips bit, remove the two 1.5mm screws.
    • Although the 2 screws are removed, the button board is still attached with a connection ribbon.
    • With a firm grip towards the bottom of the control board, gently pull away from the camera, removing the ribbon from the connector.
    Chiedi a FixBot
    Aggiungi Commento
  7. General Electric Create Jason Wu Lens Replacement: passo 7, immagine 1 di 3 General Electric Create Jason Wu Lens Replacement: passo 7, immagine 2 di 3 General Electric Create Jason Wu Lens Replacement: passo 7, immagine 3 di 3
    • Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
    • Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
    • With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
    Chiedi a FixBot
    Aggiungi Commento
  8. General Electric Create Jason Wu Lens Replacement, Lens: passo 8, immagine 1 di 2 General Electric Create Jason Wu Lens Replacement, Lens: passo 8, immagine 2 di 2
    • Locate the 2 connection ribbons attaching the lens to the circuit board.
    • Using a plastic opening tool or finger nail, gently lift the ZIF connector flaps up.
    • The connectors are hinged and will fold up and away from the ribbon, do not disconnect completely.
    Chiedi a FixBot
    Aggiungi Commento
  9. General Electric Create Jason Wu Lens Replacement: passo 9, immagine 1 di 2 General Electric Create Jason Wu Lens Replacement: passo 9, immagine 2 di 2
    • With the hinged connectors folded up and out of the way, carefully pull the ribbons out of their connectors.
    • These are the only 2 connectors holding the lens assembly in place. If disconnected the lens assembly will be completely detached from the camera.
    Chiedi a FixBot
    Aggiungi Commento
  10. General Electric Create Jason Wu Lens Replacement: passo 10, immagine 1 di 3 General Electric Create Jason Wu Lens Replacement: passo 10, immagine 2 di 3 General Electric Create Jason Wu Lens Replacement: passo 10, immagine 3 di 3
    • Firmly grasp the camera body in your right hand and grab the lens assembly with your other hand.
    • Gently pull the lens assembly directly up and out of the camera body.
    • There are no further screws or connections hold the lens assembly in place. If it does not remove easily check your previous steps.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 42
Tutti i Tempi: 615
