Introduzione
This guide will exhibit the steps necessary to replace the battery on your General Electric Create Jason Wu.
Cosa ti serve
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Using the Curved Precision Tweezers, detach battery plug from socket.
Strumento utilizzato in questo passaggio:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Swap the 3.0 Flathead bit into the precision screw driver.
On the front of the camera locate the small rectangular slot where the battery is exposed.
Use the flathead bit to gently pry on the battery to start pushing it out of the camera, allowing it to become loose.
Altre 2 persone hanno completato questa guida.
4Commenti sulla guida
Hi, when reassembling, do you need to re glue the ribbon that was taken out in step 4.
Regards
Paul
Hi,
Do you know where I can find the battery ?
