Salta al contenuto principale
GeeksPhone Keon Screen Replacement
Cosa ti serve
  1. GeeksPhone Keon Screen Replacement, Battery: passo 1, immagine 1 di 2 GeeksPhone Keon Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. GeeksPhone Keon Screen Replacement: passo 2, immagine 1 di 1
    • Lift the cover away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. GeeksPhone Keon Screen Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    Chiedi a FixBot
    Aggiungi Commento
  4. GeeksPhone Keon Screen Replacement, Back Plate: passo 4, immagine 1 di 2 GeeksPhone Keon Screen Replacement, Back Plate: passo 4, immagine 2 di 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    Chiedi a FixBot
    Aggiungi Commento
  5. GeeksPhone Keon Screen Replacement: passo 5, immagine 1 di 2 GeeksPhone Keon Screen Replacement: passo 5, immagine 2 di 2
    • Gently remove the small orange plate by pulling it down.
    Chiedi a FixBot
    Aggiungi Commento
  6. GeeksPhone Keon Screen Replacement: passo 6, immagine 1 di 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    Chiedi a FixBot
    Aggiungi Commento
  7. GeeksPhone Keon Screen Replacement: passo 7, immagine 1 di 3 GeeksPhone Keon Screen Replacement: passo 7, immagine 2 di 3 GeeksPhone Keon Screen Replacement: passo 7, immagine 3 di 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    Chiedi a FixBot
    Aggiungi Commento
  8. GeeksPhone Keon Screen Replacement: passo 8, immagine 1 di 2 GeeksPhone Keon Screen Replacement: passo 8, immagine 2 di 2
    • Lift the backplate away from the device.
    Chiedi a FixBot
    Aggiungi Commento
  9. GeeksPhone Keon Screen Replacement, Motherboard: passo 9, immagine 1 di 2 GeeksPhone Keon Screen Replacement, Motherboard: passo 9, immagine 2 di 2
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  10. GeeksPhone Keon Screen Replacement: passo 10, immagine 1 di 1
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    Chiedi a FixBot
    Aggiungi Commento
  11. GeeksPhone Keon Screen Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard from the device.
    Chiedi a FixBot
    Aggiungi Commento
  12. GeeksPhone Keon Screen Replacement, Antenna: passo 12, immagine 1 di 1
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
    Chiedi a FixBot
    Aggiungi Commento
  13. GeeksPhone Keon Screen Replacement: passo 13, immagine 1 di 3 GeeksPhone Keon Screen Replacement: passo 13, immagine 2 di 3 GeeksPhone Keon Screen Replacement: passo 13, immagine 3 di 3
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
    Chiedi a FixBot
    Aggiungi Commento
  14. GeeksPhone Keon Screen Replacement, Screen: passo 14, immagine 1 di 2 GeeksPhone Keon Screen Replacement, Screen: passo 14, immagine 2 di 2
    • Use the metal spudger to gently lift up the back of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  15. GeeksPhone Keon Screen Replacement: passo 15, immagine 1 di 2 GeeksPhone Keon Screen Replacement: passo 15, immagine 2 di 2
    • Continue to lift up the screen until it is loose from the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
DavidDrash
Membro da: 08/26/15
266 Reputazione
Una guida realizzata
USF Tampa, Team 3-5, Eyestone Fall 2015 Membro di USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 29
Tutti i Tempi: 433
