Salta al contenuto principale
GeeksPhone Keon Battery Replacement
Cosa ti serve
  1. GeeksPhone Keon Battery Replacement, Battery: passo 1, immagine 1 di 2 GeeksPhone Keon Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. GeeksPhone Keon Battery Replacement: passo 2, immagine 1 di 1
    • Lift the cover away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. GeeksPhone Keon Battery Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team 3-5, Eyestone Fall 2015 Membro di USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Membri
18 guide realizzate
4Commenti sulla guida
Newer Keon model has user replaceable battery GP-BA002
gintasdx - Rispondi Condividi
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - Rispondi Condividi
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 35
Tutti i Tempi: 1,047
