Salta al contenuto principale
GeeksPhone Keon Antenna Replacement
Cosa ti serve
  1. GeeksPhone Keon  Antenna Replacement, Battery: passo 1, immagine 1 di 2 GeeksPhone Keon  Antenna Replacement, Battery: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. GeeksPhone Keon  Antenna Replacement: passo 2, immagine 1 di 1
    • Lift the cover away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. GeeksPhone Keon  Antenna Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    Chiedi a FixBot
    Aggiungi Commento
  4. GeeksPhone Keon  Antenna Replacement, Back Plate: passo 4, immagine 1 di 2 GeeksPhone Keon  Antenna Replacement, Back Plate: passo 4, immagine 2 di 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    Chiedi a FixBot
    Aggiungi Commento
  5. GeeksPhone Keon  Antenna Replacement: passo 5, immagine 1 di 2 GeeksPhone Keon  Antenna Replacement: passo 5, immagine 2 di 2
    • Gently remove the small orange plate by pulling it down.
    Chiedi a FixBot
    Aggiungi Commento
  6. GeeksPhone Keon  Antenna Replacement: passo 6, immagine 1 di 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    Chiedi a FixBot
    Aggiungi Commento
  7. GeeksPhone Keon  Antenna Replacement: passo 7, immagine 1 di 3 GeeksPhone Keon  Antenna Replacement: passo 7, immagine 2 di 3 GeeksPhone Keon  Antenna Replacement: passo 7, immagine 3 di 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    Chiedi a FixBot
    Aggiungi Commento
  8. GeeksPhone Keon  Antenna Replacement: passo 8, immagine 1 di 2 GeeksPhone Keon  Antenna Replacement: passo 8, immagine 2 di 2
    • Lift the backplate away from the device.
    Chiedi a FixBot
    Aggiungi Commento
  9. GeeksPhone Keon  Antenna Replacement, Antenna: passo 9, immagine 1 di 1
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
    Chiedi a FixBot
    Aggiungi Commento
  10. GeeksPhone Keon  Antenna Replacement: passo 10, immagine 1 di 3 GeeksPhone Keon  Antenna Replacement: passo 10, immagine 2 di 3 GeeksPhone Keon  Antenna Replacement: passo 10, immagine 3 di 3
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Michael Moran
Membro da: 08/26/15
116 Reputazione
Una guida realizzata
USF Tampa, Team 3-5, Eyestone Fall 2015 Membro di USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 38
Tutti i Tempi: 393
