Salta al contenuto principale
Gateway W350I Keyboard Replacement
Cosa ti serve
  1. Gateway W350I Keyboard Replacement, Battery Access: passo 1, immagine 1 di 1
    • Turn the laptop upside down and position it as shown in the image.
    Chiedi a FixBot
    Aggiungi Commento
  2. Gateway W350I Keyboard Replacement, Unlocking the Battery: passo 2, immagine 1 di 3 Gateway W350I Keyboard Replacement, Unlocking the Battery: passo 2, immagine 2 di 3 Gateway W350I Keyboard Replacement, Unlocking the Battery: passo 2, immagine 3 di 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  3. Gateway W350I Keyboard Replacement, Unscrewing the Speaker Cover Panel: passo 3, immagine 1 di 1
    • Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: passo 4, immagine 1 di 2 Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: passo 4, immagine 2 di 2
    • Remove the 4mm Phillips #0 screw that secures the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Gateway W350I Keyboard Replacement, Repositioning the Device: passo 5, immagine 1 di 1
    • Reposition the laptop so that it is upright with the display open.
    Chiedi a FixBot
    Aggiungi Commento
  6. Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: passo 6, immagine 1 di 3 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: passo 6, immagine 2 di 3 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: passo 6, immagine 3 di 3
    • Carefully pry up on the right and left sides of the speaker cover panel.
    • The panel has a cable that connects it to the laptop, so do not pull the panel completely away from the laptop. Instead, disconnect the panel and move it slightly so that it does not interfere with the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Gateway W350I Keyboard Replacement, Removing the Keyboard: passo 7, immagine 1 di 2 Gateway W350I Keyboard Replacement, Removing the Keyboard: passo 7, immagine 2 di 2
    • Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  8. Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: passo 8, immagine 1 di 2 Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: passo 8, immagine 2 di 2
    • Pull on the cord connecting the keyboard to the computer until it slides out.
    • Be careful while removing the cord as it is very delicate.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Spencer
Membro da: 09/22/14
278 Reputazione
2 guide realizzate
USF Tampa, Team 4-1, Brown Fall 2014 Membro di USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Membri
10 guide realizzate
1Commento della guida
Great guide guys!
stewilli - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 52
Tutti i Tempi: 1,870
