Salta al contenuto principale
Gateway W350I Display Replacement
Cosa ti serve
    1. Gateway W350I Display Replacement, Battery Access: passo 1, immagine 1 di 1
      • Turn the laptop upside down and position it as shown in the image.
      Chiedi a FixBot
      Aggiungi Commento
    2. Gateway W350I Display Replacement, Unlocking the Battery: passo 2, immagine 1 di 3 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, immagine 2 di 3 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, immagine 3 di 3
      • Slide the locking switch towards the open lock picture.
      • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
      • Once the laptop is disengaged, completely remove the battery from the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    1. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, immagine 1 di 2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, immagine 2 di 2
      • Pry the six black rubber protectors out of the screw holes.
      • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
      Chiedi a FixBot
      Aggiungi Commento
    2. Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, immagine 1 di 2 Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, immagine 2 di 2
      • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
      Chiedi a FixBot
      Aggiungi Commento
    3. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, immagine 1 di 2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, immagine 2 di 2
      • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    4. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: passo 6, immagine 1 di 1
      • Separate the bracket and the screen from its original position within the lid of the laptop.
      • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
      Chiedi a FixBot
      Aggiungi Commento
    5. Gateway W350I Display Replacement, Remove Video Cable: passo 7, immagine 1 di 2 Gateway W350I Display Replacement, Remove Video Cable: passo 7, immagine 2 di 2
      • Detach the video cable that is attached to the laptop from the back of the screen.
      • Be careful while removing the video cable as it is very delicate.
      Chiedi a FixBot
      Aggiungi Commento
    6. Gateway W350I Display Replacement: passo 8, immagine 1 di 2 Gateway W350I Display Replacement: passo 8, immagine 2 di 2
      • Disconnect the camera connector from the circuit board to completely free the screen.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Samuel Newton
Membro da: 09/22/14
308 Reputazione
Una guida realizzata
USF Tampa, Team 4-1, Brown Fall 2014 Membro di USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Membri
20 guide realizzate
1Commento della guida
It was very easy to follow.
Very friendly guide.
stewilli - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 34
Tutti i Tempi: 1,760
