Salta al contenuto principale
Gateway NV52 WiFi Card Replacement
Cosa ti serve
    1. Gateway NV52 WiFi Card Replacement, Base Cover: passo 1, immagine 1 di 1
      • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Gateway NV52 WiFi Card Replacement: passo 2, immagine 1 di 1
      • Lift up the base cover from the the top with your hands to a 90 degree angle.
      • Remove the base cover and place it in a safe and dry place.
      Chiedi a FixBot
      Aggiungi Commento
    1. Gateway NV52 WiFi Card Replacement, WiFi Card: passo 3, immagine 1 di 1
      • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Gateway NV52 WiFi Card Replacement: passo 4, immagine 1 di 1
      • Locate the black and white cables attached to the WiFi card.
      • Gently wiggle the black cable until it detaches from the WiFi card.
      • Repeat the previous step for the white cable.
      Chiedi a FixBot
      Aggiungi Commento
    3. Gateway NV52 WiFi Card Replacement: passo 5, immagine 1 di 1
      • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Ruben
Membro da: 04/22/14
298 Reputazione
2 guide realizzate
Cal Poly, Team 7-24, Regan Spring 2014 Membro di Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membri
36 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 35
Tutti i Tempi: 1,604
