Salta al contenuto principale
Gateway 600YG2 System Fan Replacement
Cosa ti serve
    1. Gateway 600YG2 System Fan Replacement, Battery: passo 1, immagine 1 di 1
      • Flip the laptop over.
      • Slide the battery release tab to the right to open the battery cover.
      Chiedi a FixBot
      Aggiungi Commento
    2. Gateway 600YG2 System Fan Replacement: passo 2, immagine 1 di 1
      • Remove the battery cover using the tab on the right side.
      • Lift and remove the battery.
      Chiedi a FixBot
      Aggiungi Commento
    1. Gateway 600YG2 System Fan Replacement, Keyboard: passo 3, immagine 1 di 1
      • Remove the five screws holding the keyboard in place.
      Chiedi a FixBot
      Aggiungi Commento
    2. Gateway 600YG2 System Fan Replacement: passo 4, immagine 1 di 2 Gateway 600YG2 System Fan Replacement: passo 4, immagine 2 di 2
      • Possible device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
      • Possible device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
      • Follow the black ribbon cable and gently pull straight up.
      Chiedi a FixBot
      Aggiungi Commento
    1. Gateway 600YG2 System Fan Replacement, System Fan: passo 5, immagine 1 di 2 Gateway 600YG2 System Fan Replacement, System Fan: passo 5, immagine 2 di 2
      • Unscrew the four captive screws.
      • Unplug the fan from the system and pull it out. This should slide forward before coming free.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 20-10, Maness Fall 2010 Membro di Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Membri
33 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 2,689
