Salta al contenuto principale
Garmin Nuvi 680 Screen Replacement
Cosa ti serve
    1. Garmin Nuvi 680 Screen Replacement, Outer Case: passo 1, immagine 1 di 1
      • Locate the antenna on the back of the device and gently flip it open to reveal the screws underneath.
      • Remove the two 4.42 mm screws in the top-left and top-right corners of the antenna cover using a T5 Torx screwdriver
      Chiedi a FixBot
      Aggiungi Commento
    2. Garmin Nuvi 680 Screen Replacement: passo 2, immagine 1 di 1
      • Remove the antenna cover.
      • Set the removed cover aside carefully.
      Chiedi a FixBot
      Aggiungi Commento
    3. Garmin Nuvi 680 Screen Replacement: passo 3, immagine 1 di 1
      • The yellow wire is connected to the motherboard. Do not disconnect it until you finish opening the device.
      • Locate the green antenna circuit board in the middle of the case.
      • Gently use 1 or 2 fingers to grab and pull the antenna circuit board out of the middle of the case.
      Chiedi a FixBot
      Aggiungi Commento
    4. Garmin Nuvi 680 Screen Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 680 Screen Replacement: passo 4, immagine 2 di 2
      • Insert the pointed end of a spudger into the leftmost slit at the top of the antenna case, where you previously removed the circuit board
      • Once the spudger is inserted into the leftmost end of the slit at the top of the antenna case, slide it to the rightmost side of the slit.
      • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
      • Slide the antenna case out of the device.
      • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
      Chiedi a FixBot
      Aggiungi Commento
    5. Garmin Nuvi 680 Screen Replacement: passo 5, immagine 1 di 1
      • Identify the antenna assembly, which is now exposed after removing the antenna cover.
      • The two screws are positioned at the top-left and top-right corners of the antenna assembly
      • Use a T5 Torx screwdriver to remove the 10.82 mm screws from the top-left and top-right corners of the antenna assembly.
      Chiedi a FixBot
      Aggiungi Commento
    6. Garmin Nuvi 680 Screen Replacement: passo 6, immagine 1 di 2 Garmin Nuvi 680 Screen Replacement: passo 6, immagine 2 di 2
      • Locate the top side of the outer case.
      • Using your iFixit Opening Tool, gently insert a flat end of the tool into the slit of the top cover.
      • Use the Opening Tool and your hands to pull apart the front and back of the device. Grip the top and bottom sides with your hand while inserting the tool into the slit to gently separate the two halves
      • One end of the front and back of the outer case are still connected by ribbon cables.
      Chiedi a FixBot
      Aggiungi Commento
    1. Garmin Nuvi 680 Screen Replacement, Antenna: passo 7, immagine 1 di 2 Garmin Nuvi 680 Screen Replacement, Antenna: passo 7, immagine 2 di 2
      • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
      • Remove the antenna.
      Chiedi a FixBot
      Aggiungi Commento
    1. Garmin Nuvi 680 Screen Replacement, Screen Wiring: passo 8, immagine 1 di 1
      • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
      • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
      • Gently pull the ribbon cables out of their connectors. They should slide out easily.
      • Do not separate the two halves of the device yet or the on/off cable may be severed.
      Chiedi a FixBot
      Aggiungi Commento
    2. Garmin Nuvi 680 Screen Replacement: passo 9, immagine 1 di 2 Garmin Nuvi 680 Screen Replacement: passo 9, immagine 2 di 2
      • Gently pull the cable for the on/off button straight up to remove it.
      • The two halves of the device may now be separated.
      Chiedi a FixBot
      Aggiungi Commento
    1. Garmin Nuvi 680 Screen Replacement, Screen: passo 10, immagine 1 di 2 Garmin Nuvi 680 Screen Replacement, Screen: passo 10, immagine 2 di 2
      • Push the tabs towards the outside of the case, the tabs are located as shown.
      • Push the screen out of the case after the tabs are loosened.
      • Slide the screen out of the cover.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 5-22, Amido Winter 2011 Membro di Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Membri
35 guide realizzate
1Commento della guida
Great instructions, thank you
I was able to fix my GPS which I thought was headed for the recyclers.
Saved me from purchasing a replacement.
knockout - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 44
Tutti i Tempi: 10,994
