Salta al contenuto principale
Garmin GPSmap 60CSx Screen Replacement
Cosa ti serve
  1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: passo 1, immagine 1 di 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Garmin GPSmap 60CSx Screen Replacement: passo 2, immagine 1 di 1
    • Lift battery release up to remove battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Garmin GPSmap 60CSx Screen Replacement: passo 3, immagine 1 di 2 Garmin GPSmap 60CSx Screen Replacement: passo 3, immagine 2 di 2
    • Pull AA batteries out.
    Chiedi a FixBot
    Aggiungi Commento
  4. Garmin GPSmap 60CSx Screen Replacement, Screen: passo 4, immagine 1 di 2 Garmin GPSmap 60CSx Screen Replacement, Screen: passo 4, immagine 2 di 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
    Chiedi a FixBot
    Aggiungi Commento
  5. Garmin GPSmap 60CSx Screen Replacement: passo 5, immagine 1 di 1
    • Take the spudger and place it in the bottom right corner of the black PCB cover.
    • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
    • It is best to do remove the bottom corners first.
    • Pull the PCB cover out of the GPSMap 60CSx.
    Chiedi a FixBot
    Aggiungi Commento
  6. Garmin GPSmap 60CSx Screen Replacement: passo 6, immagine 1 di 2 Garmin GPSmap 60CSx Screen Replacement: passo 6, immagine 2 di 2
    • Carefully use the spudger to lift the PCB a few centimeters.
    • Pull the PCB towards the bottom of the GPSMap 60CSx.
    • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
    Chiedi a FixBot
    Aggiungi Commento
  7. Garmin GPSmap 60CSx Screen Replacement: passo 7, immagine 1 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 7, immagine 2 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 7, immagine 3 di 3
    • Apply light pressure to the four white tabs that are holding the screen in place.
    • The screen will now come off the PCB.
    Chiedi a FixBot
    Aggiungi Commento
  8. Garmin GPSmap 60CSx Screen Replacement: passo 8, immagine 1 di 1
    • Turn the PCB over so the screen connector is facing you.
    • Move the screen out of the way for access to the screen connector.
    Chiedi a FixBot
    Aggiungi Commento
  9. Garmin GPSmap 60CSx Screen Replacement: passo 9, immagine 1 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 9, immagine 2 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 9, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use tweezers to pull the two white pins on the connector forward.
    Chiedi a FixBot
    Aggiungi Commento
  10. Garmin GPSmap 60CSx Screen Replacement: passo 10, immagine 1 di 1
    • Remove the screen ribbon connector and screen.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
2Commenti sulla guida
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - Rispondi Condividi
Thank you for these step by step detailed instructions.
jlciscorp - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 15
Ultimi 30 giorni: 48
Tutti i Tempi: 5,709
