Salta al contenuto principale
Garmin Forerunner 405 Button Replacement
Cosa ti serve
  1. Garmin Forerunner 405 Button Replacement, Unscrew backing: passo 1, immagine 1 di 1
    • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
    Chiedi a FixBot
    Aggiungi Commento
  2. Garmin Forerunner 405 Button Replacement, Separate Component: passo 2, immagine 1 di 1
    • Pull the backing off the watch.
    Chiedi a FixBot
    Aggiungi Commento
  3. Garmin Forerunner 405 Button Replacement, Separate: passo 3, immagine 1 di 1
    • Pull the battery wires out from the motherboard slowly.
    Chiedi a FixBot
    Aggiungi Commento
  4. Garmin Forerunner 405 Button Replacement, Unscrew: passo 4, immagine 1 di 1
    • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
    • Lift the motherboard out of the watch.
    Chiedi a FixBot
    Aggiungi Commento
  5. Garmin Forerunner 405 Button Replacement, Pull apart: passo 5, immagine 1 di 2 Garmin Forerunner 405 Button Replacement, Pull apart: passo 5, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Push button in and pinch silver clip with tweezers.
    • Pull silver clip off the pin it is on.
    • Pull out button and replace.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
2Commenti sulla guida
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Rispondi Condividi
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 25
Tutti i Tempi: 4,094
