Salta al contenuto principale
GPD MicroPC
Cosa ti serve
  1. GPD MicroPC, Prep: passo 1, immagine 1 di 1
    • Make sure device is fully powered off, remove any connected devices and micro SD cards.
    • Based on the nature of your need, backup any sensitive documents or files before starting.
    Chiedi a FixBot
    Aggiungi Commento
  2. GPD MicroPC: passo 2, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    Phillips #00 Screwdriver
    $5.49
    • Remove 5 screws using a Phillips #00 Screwdriver
    • The opening for the screws is quite small, under 3mm. Ensure your tool has the clearance to fit.
    Chiedi a FixBot
    Aggiungi Commento
  3. GPD MicroPC: passo 3, immagine 1 di 3 GPD MicroPC: passo 3, immagine 2 di 3 GPD MicroPC: passo 3, immagine 3 di 3
    Spudger
    $3.99
    • Using a prying tool like a Spudger, pry open the bottom half.
    • There are some locking tabs on both the bottom half and the main body. There is a specific tab near the COM port which makes it tougher to pry open. It may be easier to pry from the LAN port area instead. Continue from that spot along the side towards the front audio jack and keep going until the bottom half easily comes off.
    • Remember to take out the MicroSD before continuing further
    Chiedi a FixBot
    Aggiungi Commento
  4. GPD MicroPC: passo 4, immagine 1 di 2 GPD MicroPC: passo 4, immagine 2 di 2
    • The main components are now exposed.
    • The yellow boxes are where the locking tabs are located. The orange box highlights the COM specific tab mentioned earlier.
    • To reassemble, follow these instructions in reverse.
    • For an easier time during reassembly, line up the COM tab first and ensure that it is seated properly. If that tab isn't seated right, the bottom half may not come together properly leading to potential damages.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Mike
Membro da: 11/23/18
274 Reputazione
Una guida realizzata
2Commenti sulla guida
Bonjour ,je pourrais avoir la référence de la batterie s'il vous plait merci Voici mon numéro 06 65 55 57 51
mbc - Rispondi Condividi
Information from OEM rechargeable Li-polymer battery label:
Model: 4841105-2S
Voltage: 7.6V
3100mAh 23.56Wh 2ICP5/41/105
Charge voltage:8.7V
"+" PIN1, PIN8 ; "-" PIN4, PIN5
Standard: GB31241-2014
Mfr: DONGGUAN GANFENG ELECTRONIC CO .,LTD
Apprx Size: 11cm x 4cm x 5mm*2 (there are two batteries stacked on top of each other)
Mike - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 26
Ultimi 30 giorni: 96
Tutti i Tempi: 3,216
