Salta al contenuto principale
GE Front Load Washing Machine Disassembly
Guida video
Questa guida è stata trascritta da un video di YouTube.
Cosa ti serve
      • Pull the dispenser drawer fully out and press the rear tab to release it.
      • Remove the five screws from the dispenser housing using a screwdriver with a magnetic tip.
      • Make sure the two center screws are fully backed out before pulling the console. They can rethread themselves if left partially engaged.
      Chiedi a FixBot
      Aggiungi Commento
      • Lift the left edge of the console slightly, then push it to the right to free it.
      • Confirm all dispenser screws are removed or they may block console movement.
      Chiedi a FixBot
      Aggiungi Commento
      • Remove the three small screws at the top of the washer behind the console area.
      • Slide the top panel forward and lift it away to expose the machine’s interior.
      • Remove or loosen wire ties with pliers or disconnect the console harness for more slack if needed.
      Chiedi a FixBot
      Aggiungi Commento
      • Use a small flathead screwdriver to pry off the outer door-boot retaining spring, then peel the boot edge away from the bulkhead.
      • Watch for sharp metal edges on the bulkhead while releasing the door boot.
      • Remove the two screws securing the plastic trim on the door-lock side.
      • Remove the two screws beneath the trim to free the door lock from the bulkhead.
      Chiedi a FixBot
      Aggiungi Commento
      • Remove the screws along the top and sides of the bulkhead, including the screws near the dispenser area.
      • If needed, tilt the washer slightly to loosen the three screws underneath.
      • Support the washer if tilted because it is heavy and can shift unexpectedly.
      • Remove the three screws securing the air baffle, then slide it away from the bulkhead.
      • Disconnect the wire harness on the left side before pulling the bulkhead forward.
      Chiedi a FixBot
      Aggiungi Commento
      • Reconnect the left-side wire harness behind the bulkhead before lowering the bulkhead into place.
      • Lift the bulkhead above the chassis and lower it onto the plastic mounts.
      • Align the blower fan part of the door boot with the slots on the bulkhead and secure them.
      • Reinstall all bulkhead screws, working from the outside edges in toward the center.
      Chiedi a FixBot
      Aggiungi Commento
      • Fit the door lock into position on the bulkhead and secure it with two screws.
      • Place the plastic facade over the lock and attach it with two more screws.
      • Pull the door boot onto the metal lip of the bulkhead, ensuring a tight channel fit.
      • Use a Smart Wrench to stretch the large door-boot spring back into place.
      Chiedi a FixBot
      Aggiungi Commento
      • Reseat the top panel on the washer and secure it with the three upper-edge screws.
      • Align the console with the two flat-head screws on the right side and lower it in place.
      • Push the console left until it snaps fully and locks into position.
      • Reinstall the five dispenser housing screws, noting that two middle screws are larger.
      • Slide the dispenser drawer back in until the rear tab clicks securely.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
Membro da: 01/21/25
7.128 Reputazione
224 guide realizzate
1Commento della guida
These instructions don't match the screws I have once the dispenser is removed. My model is GE GFW480SSKWW 28" 4.9 cu. ft. Front Load Steam Washer
John Walsh - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 62
Ultimi 30 giorni: 248
Tutti i Tempi: 3,362
