Salta al contenuto principale
GE A1050 LCD Replacement
Cosa ti serve
  1. GE A1050 LCD Replacement, LCD: passo 1, immagine 1 di 3 GE A1050 LCD Replacement, LCD: passo 1, immagine 2 di 3 GE A1050 LCD Replacement, LCD: passo 1, immagine 3 di 3
    • Remove the batteries, hand strap, and memory card if so equipped.
    • Remove the two Phillips screws from the bottom.
    • Remove the two Phillips screws from the left side.
    Chiedi a FixBot
    Aggiungi Commento
  2. GE A1050 LCD Replacement: passo 2, immagine 1 di 3 GE A1050 LCD Replacement: passo 2, immagine 2 di 3 GE A1050 LCD Replacement: passo 2, immagine 3 di 3
    • Remove the two screws from the right side.
    • The two screws from the left side are shorter than the ones from the right. Keep those separated.
    • Start splitting the case from the battery compartment to the sides. No special tool is needed to split the case.
    Chiedi a FixBot
    Aggiungi Commento
  3. GE A1050 LCD Replacement: passo 3, immagine 1 di 3 GE A1050 LCD Replacement: passo 3, immagine 2 di 3 GE A1050 LCD Replacement: passo 3, immagine 3 di 3
    • Do not remove the back side of the case, just flip it over. The speaker is connected by wires to the main body, but positioned in the back case.
    • Flip the LCD to the bottom. You can not yet remove it, because it is still attached to the board.
    • The LCD cable is held into the connector via some compression clips. Move both ends carefully away from the connector, toward the LCD.
    • The clips only move about an 1/8 of an inch. Be careful not to use too much force.
    Chiedi a FixBot
    Aggiungi Commento
  4. GE A1050 LCD Replacement: passo 4, immagine 1 di 1
    • After exchanging the LCD for a new one, and after reassembling your camera, you should have a working LCD.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
oldturkey03
Membro da: 09/29/10
856.555 Reputazione
123 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 48
Tutti i Tempi: 2,491
