Salta al contenuto principale
G'z One Boulder Camera Replacement
Cosa ti serve
  1. G'z One Boulder Camera Replacement, Inside Screen Cover: passo 1, immagine 1 di 1
    • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • Make note that two of the screws closest to the hinge are longer than the other two.
    Chiedi a FixBot
    Aggiungi Commento
  2. G'z One Boulder Camera Replacement: passo 2, immagine 1 di 2 G'z One Boulder Camera Replacement: passo 2, immagine 2 di 2
    • Remove the two side screws.
    • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
    Chiedi a FixBot
    Aggiungi Commento
  3. G'z One Boulder Camera Replacement: passo 3, immagine 1 di 2 G'z One Boulder Camera Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to remove the screen cover from the rest of the lid.
    Chiedi a FixBot
    Aggiungi Commento
  4. G'z One Boulder Camera Replacement: passo 4, immagine 1 di 2 G'z One Boulder Camera Replacement: passo 4, immagine 2 di 2
    • Your phone should look like the picture to the left.
    • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
    Chiedi a FixBot
    Aggiungi Commento
  5. G'z One Boulder Camera Replacement, Front Logic Board: passo 5, immagine 1 di 3 G'z One Boulder Camera Replacement, Front Logic Board: passo 5, immagine 2 di 3 G'z One Boulder Camera Replacement, Front Logic Board: passo 5, immagine 3 di 3
    • Remove one screw located on the left side of the phone with the pictured orientation in mind.
    • This will release the logic board from the back case.
    • Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
    Chiedi a FixBot
    Aggiungi Commento
  6. G'z One Boulder Camera Replacement: passo 6, immagine 1 di 3 G'z One Boulder Camera Replacement: passo 6, immagine 2 di 3 G'z One Boulder Camera Replacement: passo 6, immagine 3 di 3
    • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
    • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
    • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
    Chiedi a FixBot
    Aggiungi Commento
  7. G'z One Boulder Camera Replacement, Camera: passo 7, immagine 1 di 2 G'z One Boulder Camera Replacement, Camera: passo 7, immagine 2 di 2
    • There is a plastic square that surrounds the camera and keeps it in place. Pry this up first making note of the orientation of the part and how there is a tab pointing in the same direction as the ribbon cable.
    • Once it is loosened the surround can be removed and set aside. The next step is to detach the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  8. G'z One Boulder Camera Replacement: passo 8, immagine 1 di 2 G'z One Boulder Camera Replacement: passo 8, immagine 2 di 2
    • Now turn the phone over so that you are looking at the inside LCD and the back of the camera.
    • Use a pry stick to disconnect the ribbon cable from the rest of the PCB board.
    • Gently feed the ribbon cable through the hole to completely remove the camera from the phone. The connector pulls straight through, do not bend or twist the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  9. G'z One Boulder Camera Replacement: passo 9, immagine 1 di 1
    • These are the parts you should have now.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To disassemble your device, follow these instructions in reverse order.
Clemson, Team 13-3, Benson Spring 2013 Membro di Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Membri
21 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 23
Tutti i Tempi: 924
