Salta al contenuto principale
Function Key Motherboard
Cosa ti serve
  1. Function Key Motherboard, Front and Back Covers: passo 1, immagine 1 di 3 Function Key Motherboard, Front and Back Covers: passo 1, immagine 2 di 3 Function Key Motherboard, Front and Back Covers: passo 1, immagine 3 di 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    Chiedi a FixBot
    Aggiungi Commento
  2. Function Key Motherboard: passo 2, immagine 1 di 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    Chiedi a FixBot
    Aggiungi Commento
  3. Function Key Motherboard: passo 3, immagine 1 di 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Function Key Motherboard: passo 4, immagine 1 di 2 Function Key Motherboard: passo 4, immagine 2 di 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  5. Function Key Motherboard: passo 5, immagine 1 di 1
    • The camera should look like this once the front cover is removed.
    Chiedi a FixBot
    Aggiungi Commento
  6. Function Key Motherboard: passo 6, immagine 1 di 3 Function Key Motherboard: passo 6, immagine 2 di 3 Function Key Motherboard: passo 6, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  7. Function Key Motherboard: passo 7, immagine 1 di 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    Chiedi a FixBot
    Aggiungi Commento
  8. Function Key Motherboard, Function Key Motherboard: passo 8, immagine 1 di 3 Function Key Motherboard, Function Key Motherboard: passo 8, immagine 2 di 3 Function Key Motherboard, Function Key Motherboard: passo 8, immagine 3 di 3
    • Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
    • Caution: Do not tug on the LCD screen because this could tear the ribbon connecting the LCD screen to the body of the camera.
    • Loosen the black ribbon clamp using an iPod opening tool
    • Release the LCD screen by removing the ribbon from the body of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  9. Function Key Motherboard: passo 9, immagine 1 di 2 Function Key Motherboard: passo 9, immagine 2 di 2
    • Unscrew 2 3.35mm phillips head screw from the face of the function key motherboard using a #00 phillips head screwdriver.
    • Caution: Do not tug on the motherboard because this will tear the ribbon connecting the motherboard to the body of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  10. Function Key Motherboard: passo 10, immagine 1 di 3 Function Key Motherboard: passo 10, immagine 2 di 3 Function Key Motherboard: passo 10, immagine 3 di 3
    • Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
    • Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
    • The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 8-6, Regan Spring 2011 Membro di Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membri
22 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 50
Tutti i Tempi: 3,724
