Salta al contenuto principale
Fujitsu LIFEBOOK P7010D Keyboard Replacement
Cosa ti serve
  1. Fujitsu LIFEBOOK P7010D Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop upside down on a table.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 2, immagine 1 di 1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery, as pictured.
    • Using two fingers, press both tabs down at once until they are fully depressed.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 3, immagine 1 di 1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fujitsu LIFEBOOK P7010D Keyboard Replacement, Keyboard: passo 4, immagine 1 di 2 Fujitsu LIFEBOOK P7010D Keyboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0.
    • Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
    Chiedi a FixBot
    Aggiungi Commento
  5. Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 5, immagine 1 di 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 5, immagine 2 di 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 5, immagine 3 di 3
    • Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer.
    • Raise the monitor as you normally would until it pops out by itself. Rotate the left side up and to the right to unhook hinges that may catch on the computer.
    • Lay the monitor flat next to the computer.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 6, immagine 1 di 2 Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 6, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons.
    • Lift the case out and set it aside.
    • For the proceeding steps, put on your anti-static wrist strap and attach the metal clip to something metal and grounded in order to protect the delicate circuitry inside the computer.
    Chiedi a FixBot
    Aggiungi Commento
  7. Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 7, immagine 1 di 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 7, immagine 2 di 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 7, immagine 3 di 3
    • Using the same spudger, pry the top of the keyboard up above the "F2" key.
    • Turn the computer so that the bottom is facing you.
    • The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
    Chiedi a FixBot
    Aggiungi Commento
  8. Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 8, immagine 1 di 2 Fujitsu LIFEBOOK P7010D Keyboard Replacement: passo 8, immagine 2 di 2
    • Disconnect the keyboard by gently pulling on the hard plastic square straight up from the white connector.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 10-31, Amido Winter 2012 Membro di Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
5 Membri
21 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 52
Tutti i Tempi: 4,968
