Salta al contenuto principale
Front Inner Tube Replacement
    1. Front Inner Tube Replacement, Front Inner Tube: passo 1, immagine 1 di 2 Front Inner Tube Replacement, Front Inner Tube: passo 1, immagine 2 di 2
      • First, remove the front wheel from the frame by unscrewing the adjustable screw
      Chiedi a FixBot
      Aggiungi Commento
    2. Front Inner Tube Replacement: passo 2, immagine 1 di 3 Front Inner Tube Replacement: passo 2, immagine 2 di 3 Front Inner Tube Replacement: passo 2, immagine 3 di 3
      • Next, wedge tire tool below the bike wheel, right above the rim.
      • Once firmly in place, push the tire tool down towards the ground in order to create spacing between the tire and the rim.
      • Following this, grab the 2nd tire tool and place it into the gap you have created.
      • Slide the 2nd tool around the entire circumference of the tire, while holding the first in place, in order to dislodge the tire from the rim.
      Chiedi a FixBot
      Aggiungi Commento
    3. Front Inner Tube Replacement: passo 3, immagine 1 di 2 Front Inner Tube Replacement: passo 3, immagine 2 di 2
      • After removing the bike tire, locate the bike valve used to pump air into the tire.
      • Gently remove the inner tube starting with the area around the valve.
      • Make a note of where the hole for the valve is located on the bike rim, because that is where the next step begins.
      Chiedi a FixBot
      Aggiungi Commento
    4. Front Inner Tube Replacement: passo 4, immagine 1 di 1
      • Pump a small amount of air into the new bike tube so that it is easier to work with.
      • Next, locate the hole in the bike rim and feed the valve through and into position.
      • Next, wrap the rest of the tubing over the rim comfortably, while making sure that no folds or creases form on the tube.
      Chiedi a FixBot
      Aggiungi Commento
    5. Front Inner Tube Replacement: passo 5, immagine 1 di 2 Front Inner Tube Replacement: passo 5, immagine 2 di 2
      • Finish by placing the bike tire back on the the frame, while making sure that no fold or creases form in the tube.
      • Lastly, pump air into the tire and remount onto bike frame.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions.
Altre 4 persone hanno completato questa guida.
Theo Tzeng
Membro da: 07/22/13
74 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 35
Ultimi 30 giorni: 173
Tutti i Tempi: 3,463
