Salta al contenuto principale
Framework Laptop 16" Display Replacement
Cosa ti serve
  1. Framework Laptop 16" Display Replacement, Before you begin: passo 1, immagine 1 di 2 Framework Laptop 16" Display Replacement, Before you begin: passo 1, immagine 2 di 2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Display Replacement, Create a gap: passo 2, immagine 1 di 3 Framework Laptop 16" Display Replacement, Create a gap: passo 2, immagine 2 di 3 Framework Laptop 16" Display Replacement, Create a gap: passo 2, immagine 3 di 3
    • The bezel is secured with magnets!
    • Slide your fingernail under the inside edge of either bottom corner of the bezel.
    • Pull the bezel away from the screen to release the first few magnets.
  3. Framework Laptop 16" Display Replacement, Remove the bezel: passo 3, immagine 1 di 3 Framework Laptop 16" Display Replacement, Remove the bezel: passo 3, immagine 2 di 3 Framework Laptop 16" Display Replacement, Remove the bezel: passo 3, immagine 3 di 3
    • Lift the bezel around the perimeter of the screen until all of its magnets are released.
    • Remove the bezel.
  4. Framework Laptop 16" Display Replacement, Remove the display screws: passo 4, immagine 1 di 3 Framework Laptop 16" Display Replacement, Remove the display screws: passo 4, immagine 2 di 3 Framework Laptop 16" Display Replacement, Remove the display screws: passo 4, immagine 3 di 3
    • Use a T5 Torx screwdriver to remove the four 2.4 mm‑long screws securing the display.
    • During reassembly, support the screen frame with your other hand as you reinsert screws to prevent the laptop from accidentally tipping over.
  5. Framework Laptop 16" Display Replacement, Disconnect the display: passo 5, immagine 1 di 3 Framework Laptop 16" Display Replacement, Disconnect the display: passo 5, immagine 2 di 3 Framework Laptop 16" Display Replacement, Disconnect the display: passo 5, immagine 3 di 3
    • Grab the display and pull it straight off the screen frame to free it from its alignment pegs.
    • Don't pull the display too far from the frame, as it's still attached by a cable.
    • Flip the front of the display down and rest it on the keyboard.
  6. Framework Laptop 16" Display Replacement: passo 6, immagine 1 di 2 Framework Laptop 16" Display Replacement: passo 6, immagine 2 di 2
    • Use your fingers to flip up the plastic tab and access the connector underneath.
  7. Framework Laptop 16" Display Replacement: passo 7, immagine 1 di 2 Framework Laptop 16" Display Replacement: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to lift up the metal locking tab over the display connector.
  8. Framework Laptop 16" Display Replacement, Remove the display: passo 8, immagine 1 di 3 Framework Laptop 16" Display Replacement, Remove the display: passo 8, immagine 2 di 3 Framework Laptop 16" Display Replacement, Remove the display: passo 8, immagine 3 di 3
    • Grip the display cable where it meets the connector head.
    • Slide the connector straight out of its socket to disconnect it.
    • Remove the display.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Altre 2 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
213.142 Reputazione
1.040 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.629 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 52
Tutti i Tempi: 1,200
