Salta al contenuto principale
Framework Laptop 16 Graphics Module Fan Replacement
Cosa ti serve
  1. Framework Laptop 16 Graphics Module Fan Replacement, Before you begin: passo 1, immagine 1 di 1
    • Unplug all cables and fully shut down your laptop.
  2. Framework Laptop 16 Graphics Module Fan Replacement, Unlock the Input Modules: passo 2, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Unlock the Input Modules: passo 2, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Unlock the Input Modules: passo 2, immagine 3 di 3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Spacers: passo 3, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Spacers: passo 3, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Spacers: passo 3, immagine 3 di 3
    • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the Touchpad Spacer off the laptop and remove it.
  4. Framework Laptop 16 Graphics Module Fan Replacement: passo 4, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement: passo 4, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement: passo 4, immagine 3 di 3
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Module: passo 5, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Module: passo 5, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Touchpad Module: passo 5, immagine 3 di 3
    • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the Touchpad Module and remove it.
  6. Framework Laptop 16 Graphics Module Fan Replacement, Remove the keyboard: passo 6, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the keyboard: passo 6, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the keyboard: passo 6, immagine 3 di 3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
    • Remove the keyboard.
  7. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Input Modules: passo 7, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Input Modules: passo 7, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Input Modules: passo 7, immagine 3 di 3
    • Your Input Module(s) might be different, but the procedure to remove them is the same.
    • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
    • Remove the Input Module.
    • Repeat for any remaining Input Modules.
  8. Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: passo 8, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: passo 8, immagine 2 di 2
    • Lift the interposer door by its black pull tab and let it rest upright.
  9. Framework Laptop 16 Graphics Module Fan Replacement, Loosen the interposer screws: passo 9, immagine 1 di 1
    • Use your Framework Screwdriver to loosen the four captive T5 Torx screws securing the interposer.
  10. Framework Laptop 16 Graphics Module Fan Replacement, Remove the interposer: passo 10, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Remove the interposer: passo 10, immagine 2 di 2
    • Lift the interposer by its pull tab and remove it.
  11. Framework Laptop 16 Graphics Module Fan Replacement, Loosen the Graphics Module screws: passo 11, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Loosen the Graphics Module screws: passo 11, immagine 2 di 2
    • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the Graphics Module.
    • Close the interposer door before continuing.
  12. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module: passo 12, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module: passo 12, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module: passo 12, immagine 3 di 3
    • Close your laptop and flip it over.
    • Slide the Graphics Module out of the laptop and remove it.
    • The module should slide out easily. If you feel any resistance, check that the screws holding it in place are fully loosened.
  13. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover screws: passo 13, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover screws: passo 13, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover screws: passo 13, immagine 3 di 3
    • Use your Framework Screwdriver to remove the four 3.6 mm‑long T5 Torx screws securing the Graphics Module cover:
    • Two screws on the flat surface of the module, next to the fans.
    • Two screws on the thin edge of the module, near the ends. You'll need to flip the module on its back edge to access them.
  14. Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover: passo 14, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover: passo 14, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the Graphics Module cover: passo 14, immagine 3 di 3
    • Use your fingers to lift the cover off the Graphics Module and remove it.
  15. Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: passo 15, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: passo 15, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Disconnect the fan: passo 15, immagine 3 di 3
    • Use the flat end of a spudger, or a clean fingernail, to lift up and release the locking tab on the fan ZIF connector.
    • Use your fingers to grip the brown pull tab and slide the fan cable straight out of its socket.
  16. Framework Laptop 16 Graphics Module Fan Replacement, Loosen the fan screws: passo 16, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Loosen the fan screws: passo 16, immagine 2 di 2
    • Use a T5 Torx screwdriver to loosen the four captive screws securing the fan.
  17. Framework Laptop 16 Graphics Module Fan Replacement, Remove the fan: passo 17, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the fan: passo 17, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the fan: passo 17, immagine 3 di 3
    • Use one hand to press the fan cable flat to the module.
    • Use your other hand to pull the fan out of its housing, making sure to thread the cable though its slot.
    • Remove the fan.
  18. Framework Laptop 16 Graphics Module Fan Replacement, Disassembly complete: passo 18, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  19. Framework Laptop 16 Graphics Module Fan Replacement, Place the fan: passo 19, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Place the fan: passo 19, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Place the fan: passo 19, immagine 3 di 3
    • Place the fan onto the Expansion Bay Shell, making sure to thread the cable through its slot.
  20. Framework Laptop 16 Graphics Module Fan Replacement, Install the fan screws: passo 20, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Install the fan screws: passo 20, immagine 2 di 2
    • Use a T5 Torx screwdriver to tighten the four captive screws securing the fan.
  21. Framework Laptop 16 Graphics Module Fan Replacement, Connect the fan: passo 21, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Connect the fan: passo 21, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Connect the fan: passo 21, immagine 3 di 3
    • Use your fingers to grip the brown pull tab and slide the fan cable straight into its socket.
    • Use the flat end of your Framework Screwdriver, or a clean fingernail, to press down the locking tab on the fan ZIF connector.
  22. Framework Laptop 16 Graphics Module Fan Replacement, Place the Graphics Module cover: passo 22, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Place the Graphics Module cover: passo 22, immagine 2 di 2
    • Place the cover over its slot on the Graphics Module.
  23. Framework Laptop 16 Graphics Module Fan Replacement, Install the Graphics Module cover screws: passo 23, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Graphics Module cover screws: passo 23, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Graphics Module cover screws: passo 23, immagine 3 di 3
    • Use your Framework Screwdriver to install the four 3.6 mm‑long T5 Torx screws securing the Graphics Module cover:
  24. Framework Laptop 16 Graphics Module Fan Replacement, Insert the Graphics Module: passo 24, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Insert the Graphics Module: passo 24, immagine 2 di 2
  25. Framework Laptop 16 Graphics Module Fan Replacement: passo 25, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement: passo 25, immagine 2 di 2
    • When installing the module, keep it level to the laptop so it doesn't buckle on the rails.
    • There should be no gaps between the laptop and the module when it's installed correctly.
  26. Framework Laptop 16 Graphics Module Fan Replacement: passo 26, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement: passo 26, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement: passo 26, immagine 3 di 3
    • While keeping the module level with the laptop, slide it into its slot.
    • The module should slide in easily. If you feel any resistance, pull the module out and realign it.
    • You should hear an audible "click" when the module's clips snap into place.
  27. Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: passo 27, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Lift the interposer door: passo 27, immagine 2 di 2
    • Flip over the laptop and open it.
  28. Framework Laptop 16 Graphics Module Fan Replacement, Tighten the Graphics Module screws: passo 28, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Tighten the Graphics Module screws: passo 28, immagine 2 di 2
    • Use your Framework Screwdriver to tighten the two captive T5 Torx screws securing the Graphics Module.
  29. Framework Laptop 16 Graphics Module Fan Replacement, Place the interposer: passo 29, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Place the interposer: passo 29, immagine 2 di 2
    • Place the interposer over its spot between the Mainboard and the Graphics Module.
  30. Framework Laptop 16 Graphics Module Fan Replacement, Tighten the interposer screws: passo 30, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Tighten the interposer screws: passo 30, immagine 2 di 2
    • Use your Framework Screwdriver to tighten the four captive T5 Torx screws securing the interposer.
    • Close the interposer door.
  31. Framework Laptop 16 Graphics Module Fan Replacement, Remove the numpad: passo 31, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the numpad: passo 31, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Remove the numpad: passo 31, immagine 3 di 3
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  32. Framework Laptop 16 Graphics Module Fan Replacement, Install the keyboard: passo 32, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the keyboard: passo 32, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the keyboard: passo 32, immagine 3 di 3
    • Align the top edge of the keyboard with the top edge of the laptop.
    • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
    • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  33. Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Module: passo 33, immagine 1 di 2 Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Module: passo 33, immagine 2 di 2
    • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
    • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  34. Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Spacers: passo 34, immagine 1 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Spacers: passo 34, immagine 2 di 3 Framework Laptop 16 Graphics Module Fan Replacement, Install the Touchpad Spacers: passo 34, immagine 3 di 3
    • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
    • Slide the Touchpad Spacer towards the top of the laptop to secure it.
    • Repeat the same procedure for the other Touchpad Spacer.
Conclusione
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membro da: 01/16/22
218.717 Reputazione
1.087 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 15
