Salta al contenuto principale
Framework Desktop Fastener Kit
Cosa ti serve
  1. Framework Desktop Fastener Kit, Fastener information: passo 1, immagine 1 di 2 Framework Desktop Fastener Kit, Fastener information: passo 1, immagine 2 di 2
    • The Fastener Kit contains the following:
    • Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
    • Two large screws labeled "M6 ring screws"
    • Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
    • Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
    • Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
    • Your Framework Desktop comes with a spare screw of each size attached to the bottom of the top plate. You can use the Fastener Kit to replenish any screws you used there.
    • Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
    Chiedi a FixBot
    Aggiungi Commento
  2. Framework Desktop Fastener Kit, Top Panel screws: passo 2, immagine 1 di 3 Framework Desktop Fastener Kit, Top Panel screws: passo 2, immagine 2 di 3 Framework Desktop Fastener Kit, Top Panel screws: passo 2, immagine 3 di 3
    • The two screws labeled "M6 ring screws" secure the Top Panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. Framework Desktop Fastener Kit, Fan screws: passo 3, immagine 1 di 2 Framework Desktop Fastener Kit, Fan screws: passo 3, immagine 2 di 2
    • The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
    Chiedi a FixBot
    Aggiungi Commento
  4. Framework Desktop Fastener Kit, Mainboard screws: passo 4, immagine 1 di 2 Framework Desktop Fastener Kit, Mainboard screws: passo 4, immagine 2 di 2
    • The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Framework Desktop Fastener Kit, Power supply screws: passo 5, immagine 1 di 2 Framework Desktop Fastener Kit, Power supply screws: passo 5, immagine 2 di 2
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
    Chiedi a FixBot
    Aggiungi Commento
  6. Framework Desktop Fastener Kit, Top plate screws: passo 6, immagine 1 di 3 Framework Desktop Fastener Kit, Top plate screws: passo 6, immagine 2 di 3 Framework Desktop Fastener Kit, Top plate screws: passo 6, immagine 3 di 3
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
    Chiedi a FixBot
    Aggiungi Commento
  7. Framework Desktop Fastener Kit, Rear plate screws: passo 7, immagine 1 di 3 Framework Desktop Fastener Kit, Rear plate screws: passo 7, immagine 2 di 3 Framework Desktop Fastener Kit, Rear plate screws: passo 7, immagine 3 di 3
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
    Chiedi a FixBot
    Aggiungi Commento
  8. Framework Desktop Fastener Kit, Side power supply screw: passo 8, immagine 1 di 2 Framework Desktop Fastener Kit, Side power supply screw: passo 8, immagine 2 di 2
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
    Chiedi a FixBot
    Aggiungi Commento
  9. Framework Desktop Fastener Kit, Power duct screws: passo 9, immagine 1 di 3 Framework Desktop Fastener Kit, Power duct screws: passo 9, immagine 2 di 3 Framework Desktop Fastener Kit, Power duct screws: passo 9, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membro da: 01/16/22
244.886 Reputazione
1.203 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 21
Tutti i Tempi: 269
