Salta al contenuto principale
Flip Video Ultra USB connector Replacement
Cosa ti serve
  1. Flip Video Ultra USB connector Replacement, USB connector: passo 1, immagine 1 di 1
    • Unlock the battery cover by sliding the switch to the unlock position.
    Chiedi a FixBot
    Aggiungi Commento
  2. Flip Video Ultra USB connector Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by sliding it down the camera.
    Chiedi a FixBot
    Aggiungi Commento
  3. Flip Video Ultra USB connector Replacement: passo 3, immagine 1 di 1
    • Remove the batteries.
    Chiedi a FixBot
    Aggiungi Commento
  4. Flip Video Ultra USB connector Replacement: passo 4, immagine 1 di 1
    • Slide the black upper casing off from the device.
    • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
    Chiedi a FixBot
    Aggiungi Commento
  5. Flip Video Ultra USB connector Replacement: passo 5, immagine 1 di 2 Flip Video Ultra USB connector Replacement: passo 5, immagine 2 di 2
    • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  6. Flip Video Ultra USB connector Replacement: passo 6, immagine 1 di 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  7. Flip Video Ultra USB connector Replacement: passo 7, immagine 1 di 2 Flip Video Ultra USB connector Replacement: passo 7, immagine 2 di 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. Flip Video Ultra USB connector Replacement: passo 8, immagine 1 di 2 Flip Video Ultra USB connector Replacement: passo 8, immagine 2 di 2
    • Gently separate the circuit board from the casing.
    Chiedi a FixBot
    Aggiungi Commento
  9. Flip Video Ultra USB connector Replacement: passo 9, immagine 1 di 2 Flip Video Ultra USB connector Replacement: passo 9, immagine 2 di 2
    • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  10. Flip Video Ultra USB connector Replacement: passo 10, immagine 1 di 2 Flip Video Ultra USB connector Replacement: passo 10, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Gently lift the usb connector using the Plastic opening tool.
    • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
    • The connector will be easier to remove if you wiggle the tweezers while lifting.
    Chiedi a FixBot
    Aggiungi Commento
  11. Flip Video Ultra USB connector Replacement: passo 11, immagine 1 di 1
    • Fully remove the USB connector and replace it with the new USB connector.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
UMass Dartmouth, Team 5-7, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Membri
10 guide realizzate
2Commenti sulla guida
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - Rispondi Condividi
Where do you purchase the replacement usb connector?
DeEtte Moore - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 44
Tutti i Tempi: 1,566
