Salta al contenuto principale
Flip Video LCD Screen
Cosa ti serve
    1. Flip Video LCD Screen, Outer Shell: passo 1, immagine 1 di 2 Flip Video LCD Screen, Outer Shell: passo 1, immagine 2 di 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Chiedi a FixBot
      Aggiungi Commento
    2. Flip Video LCD Screen: passo 2, immagine 1 di 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Chiedi a FixBot
      Aggiungi Commento
    3. Flip Video LCD Screen: passo 3, immagine 1 di 2 Flip Video LCD Screen: passo 3, immagine 2 di 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Chiedi a FixBot
      Aggiungi Commento
    4. Flip Video LCD Screen: passo 4, immagine 1 di 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Chiedi a FixBot
      Aggiungi Commento
    5. Flip Video LCD Screen: passo 5, immagine 1 di 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Chiedi a FixBot
      Aggiungi Commento
    1. Flip Video LCD Screen, Circuit Board: passo 6, immagine 1 di 1
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Flip Video LCD Screen: passo 7, immagine 1 di 1
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. Flip Video LCD Screen: passo 8, immagine 1 di 1
      • Disconnect the USB port cable from the back side of the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    4. Flip Video LCD Screen: passo 9, immagine 1 di 1
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Chiedi a FixBot
      Aggiungi Commento
    1. Flip Video LCD Screen, LCD Screen: passo 10, immagine 1 di 1
      • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Flip Video LCD Screen: passo 11, immagine 1 di 1
      • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
      Chiedi a FixBot
      Aggiungi Commento
    3. Flip Video LCD Screen: passo 12, immagine 1 di 1
      • Gently pull out ribbon cable.
      • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
      • The LCD screen is now removed and can be replaced.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Elizabeth
Membro da: 04/15/10
100 Reputazione
6 guide realizzate
Cal Poly, Team 26-21, Regan Spring 2010 Membro di Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 32
Tutti i Tempi: 5,747
