Salta al contenuto principale
Fix the Short in the Plug Guide
Cosa ti serve
  1. Fix the Short in the Plug Guide, Fix the Short in the Plug Guide: passo 1, immagine 1 di 1
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fix the Short in the Plug Guide: passo 2, immagine 1 di 1
    • Locate all exposed portions of the wire.
    • Tape over any exposed portions of the wire with electrical tape.
    • Use this power cord temporarily.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fix the Short in the Plug Guide: passo 3, immagine 1 di 1
    • Plug the power cord into the outlet and make sure the power cord is connected to the device. If not, connect the power cord to the back of the device.
    • Replace the damaged cable by purchasing a new cable at your local hardware store.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 1,867
