Salta al contenuto principale
Fender Starcaster Tuning Heads Replacement
Cosa ti serve
    1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: passo 1, immagine 1 di 3 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: passo 1, immagine 2 di 3 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: passo 1, immagine 3 di 3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 1 di 2 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 2 di 2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: passo 3, immagine 1 di 3 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: passo 3, immagine 2 di 3 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: passo 3, immagine 3 di 3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      Chiedi a FixBot
      Aggiungi Commento
    1. Fender Starcaster Tuning Heads Replacement, Tuning Heads: passo 4, immagine 1 di 2 Fender Starcaster Tuning Heads Replacement, Tuning Heads: passo 4, immagine 2 di 2
      • Using a wrench, remove the nuts around each tuning head post.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fender Starcaster Tuning Heads Replacement: passo 5, immagine 1 di 3 Fender Starcaster Tuning Heads Replacement: passo 5, immagine 2 di 3 Fender Starcaster Tuning Heads Replacement: passo 5, immagine 3 di 3
      • Next, remove the threaded retainer sleeve from each post.
      • Don't forget the washer.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fender Starcaster Tuning Heads Replacement: passo 6, immagine 1 di 2 Fender Starcaster Tuning Heads Replacement: passo 6, immagine 2 di 2
      • Next, remove the screws from the backside of each tuner.
      Chiedi a FixBot
      Aggiungi Commento
    4. Fender Starcaster Tuning Heads Replacement: passo 7, immagine 1 di 2 Fender Starcaster Tuning Heads Replacement: passo 7, immagine 2 di 2
      • Finally, remove the tuning machine assembly from the headstock.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
3Commenti sulla guida
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - Rispondi Condividi
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - Rispondi Condividi
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 43
Tutti i Tempi: 3,404
