Salta al contenuto principale
Fender Starcaster String Replacement
Cosa ti serve
  1. Fender Starcaster String Replacement, Loosen the Strings: passo 1, immagine 1 di 3 Fender Starcaster String Replacement, Loosen the Strings: passo 1, immagine 2 di 3 Fender Starcaster String Replacement, Loosen the Strings: passo 1, immagine 3 di 3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 1 di 2 Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 2 di 2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fender Starcaster String Replacement, Remove the Strings from the Bridge: passo 3, immagine 1 di 3 Fender Starcaster String Replacement, Remove the Strings from the Bridge: passo 3, immagine 2 di 3 Fender Starcaster String Replacement, Remove the Strings from the Bridge: passo 3, immagine 3 di 3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fender Starcaster String Replacement, String: passo 4, immagine 1 di 3 Fender Starcaster String Replacement, String: passo 4, immagine 2 di 3 Fender Starcaster String Replacement, String: passo 4, immagine 3 di 3
    • Take any one of the new strings and slide it through the appropriate bridge hole.
    • The replacement strings used on this guitar were "Regular Slinky" by Ernie Ball, which is a 10 gauge string set.
    • 6th String: E - 46 Gauge
    • 5th String: A - 36 Gauge
    • 4th String: D - 26 Gauge
    • 3rd String: G - 17 Gauge
    • 2nd String: B - 13 Gauge
    • 1st String: E - 10 Guage
    Chiedi a FixBot
    Aggiungi Commento
  5. Fender Starcaster String Replacement: passo 5, immagine 1 di 3 Fender Starcaster String Replacement: passo 5, immagine 2 di 3 Fender Starcaster String Replacement: passo 5, immagine 3 di 3
    • Lay the string parallel to the guitar's neck and directly over the appropriate tuning peg.
    • Measure a "three finger's length" (about 1.5") on the string passed the tuning peg.
    • Make a sharp bend in the string at where you measured 1.5" passed the tuning peg.
    • Turn the tuning peg until the string hole faces perpendicular to the guitar's neck.
    • Feed the bent string into the tuning peg until the bend meets the tuning post.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fender Starcaster String Replacement: passo 6, immagine 1 di 3 Fender Starcaster String Replacement: passo 6, immagine 2 di 3 Fender Starcaster String Replacement: passo 6, immagine 3 di 3
    • Make another sharp bend in the string on the outside of the tuning post.
    • Turn the tuning key counter clockwise while applying light pressure to the string on the inside of the post.
    • Wrapping the string around the post will help the string stay in-tune longer.
    • If the wraps of the string around the post start to roll over the top of the post, hold them down while still turning the post.
    • Continue turning the post until at least 2 full wraps of the string have been made around the post.
    Chiedi a FixBot
    Aggiungi Commento
  7. Fender Starcaster String Replacement: passo 7, immagine 1 di 2 Fender Starcaster String Replacement: passo 7, immagine 2 di 2
    • Snip the excess string off from the post with a wire cutter (leaving at least half an inch of string left).
    Chiedi a FixBot
    Aggiungi Commento
  8. Fender Starcaster String Replacement: passo 8, immagine 1 di 3 Fender Starcaster String Replacement: passo 8, immagine 2 di 3 Fender Starcaster String Replacement: passo 8, immagine 3 di 3
    • Continue installing strings using the the same method described in the last few steps.
    • The last four strings (the D, G, B, and E strings), must be guided underneath the two "string trees" in the center of the headstock.
    • String Tree for the D and G strings
    • String Tree for the B and E strings
    • Tune the strings to your desired pitch and your guitar is ready to play!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Jasper Fleischhauer
Membro da: 10/20/14
37.074 Reputazione
2 guide realizzate
1Commento della guida
Good guide very helpful.
Neo kramer - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 53
Tutti i Tempi: 6,963
