Salta al contenuto principale
Fender Starcaster Bridge Replacement
Cosa ti serve
    1. Fender Starcaster Bridge Replacement, Loosen the Strings: passo 1, immagine 1 di 3 Fender Starcaster Bridge Replacement, Loosen the Strings: passo 1, immagine 2 di 3 Fender Starcaster Bridge Replacement, Loosen the Strings: passo 1, immagine 3 di 3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 1 di 2 Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 2 di 2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: passo 3, immagine 1 di 3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: passo 3, immagine 2 di 3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: passo 3, immagine 3 di 3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      Chiedi a FixBot
      Aggiungi Commento
    1. Fender Starcaster Bridge Replacement, Bridge: passo 4, immagine 1 di 2 Fender Starcaster Bridge Replacement, Bridge: passo 4, immagine 2 di 2
      • On the back of the guitar, remove the plate covering the spring cavity. In the spring cavity, reduce the tension on the bridge springs by first loosening the retainer screws a bit.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fender Starcaster Bridge Replacement: passo 5, immagine 1 di 3 Fender Starcaster Bridge Replacement: passo 5, immagine 2 di 3 Fender Starcaster Bridge Replacement: passo 5, immagine 3 di 3
      • To remove the springs from the bridge, grip the end with pliers and pull up.
      • It is safe to use the body of the guitar for leverage.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fender Starcaster Bridge Replacement: passo 6, immagine 1 di 3 Fender Starcaster Bridge Replacement: passo 6, immagine 2 di 3 Fender Starcaster Bridge Replacement: passo 6, immagine 3 di 3
      • Be aware that the ground wire for the electronics of the guitar is routed through the body and soldered to the spring retainer.
      Chiedi a FixBot
      Aggiungi Commento
    4. Fender Starcaster Bridge Replacement: passo 7, immagine 1 di 3 Fender Starcaster Bridge Replacement: passo 7, immagine 2 di 3 Fender Starcaster Bridge Replacement: passo 7, immagine 3 di 3
      • Remove the screws from the front of the bridge.
      • It may be helpful to only loosen the outer screws as you remove the inner screws, in order to prevent damage to the guitar.
      Chiedi a FixBot
      Aggiungi Commento
    5. Fender Starcaster Bridge Replacement: passo 8, immagine 1 di 1
      • With all six screws removed, lift up on the bridge to remove it from the body.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 43
Tutti i Tempi: 3,126
