Salta al contenuto principale
Fellowes T7CM Shaft Replacement
Cosa ti serve
    1. Fellowes T7CM Shaft Replacement, Fellowes T7CM Casing and Trigger Replacement: passo 1, immagine 1 di 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fellowes T7CM Shaft Replacement: passo 2, immagine 1 di 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fellowes T7CM Shaft Replacement: passo 3, immagine 1 di 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      Chiedi a FixBot
      Aggiungi Commento
    4. Fellowes T7CM Shaft Replacement: passo 4, immagine 1 di 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      Chiedi a FixBot
      Aggiungi Commento
    1. Fellowes T7CM Shaft Replacement, Gear and Shaft: passo 5, immagine 1 di 2 Fellowes T7CM Shaft Replacement, Gear and Shaft: passo 5, immagine 2 di 2
      • Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
      • Remove the internal case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fellowes T7CM Shaft Replacement: passo 6, immagine 1 di 1
      • Remove the feeding sensor by unscrewing the single screw holding it. The screw length is 10 mm and the head diameter is 6 mm.
      • This step may be unnecessary, but it will prevent the sensor from being damaged.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fellowes T7CM Shaft Replacement: passo 7, immagine 1 di 2 Fellowes T7CM Shaft Replacement: passo 7, immagine 2 di 2
      • Remove the six screws on the gearbox.
      • Remove the gearbox cover to expose the gears.
      • The screw length is 34 mm and the head diameter is 7 mm.
      • The screw length is 26 mm and the head diameter is 7 mm.
      Chiedi a FixBot
      Aggiungi Commento
    4. Fellowes T7CM Shaft Replacement: passo 8, immagine 1 di 3 Fellowes T7CM Shaft Replacement: passo 8, immagine 2 di 3 Fellowes T7CM Shaft Replacement: passo 8, immagine 3 di 3
      • Remove the gears.
      • The larger gear located in the middle may require a screwdriver to pry off.
      • Remove the gear holder by unscrewing two screws that are holding it in place. The screw length is 14 mm and the head diameter is 5 mm.
      Chiedi a FixBot
      Aggiungi Commento
    5. Fellowes T7CM Shaft Replacement: passo 9, immagine 1 di 2 Fellowes T7CM Shaft Replacement: passo 9, immagine 2 di 2
      • Remove the pin in order to pull the casing off of the shafts.
      • Remove the casing in order to expose shafts.
      Chiedi a FixBot
      Aggiungi Commento
    1. Fellowes T7CM Shaft Replacement, Shaft: passo 10, immagine 1 di 1
      • Remove the metal attachment that holds the two shafts together.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fellowes T7CM Shaft Replacement: passo 11, immagine 1 di 1
      • The shafts can now be pulled apart and any obstructions located between or on each of the shafts can be removed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team 2-2, Baechle Fall 2016 Membro di IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 31
Tutti i Tempi: 1,740
