Salta al contenuto principale
Fellowes T7CM On, Off, Reverse Switch Replacement
Cosa ti serve
    1. Fellowes T7CM On,  Off, Reverse Switch Replacement, Fellowes T7CM Casing and Trigger Replacement: passo 1, immagine 1 di 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 2, immagine 1 di 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 3, immagine 1 di 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      Chiedi a FixBot
      Aggiungi Commento
    4. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 4, immagine 1 di 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      Chiedi a FixBot
      Aggiungi Commento
    1. Fellowes T7CM On,  Off, Reverse Switch Replacement, On,  Off, Reverse Switch: passo 5, immagine 1 di 1
      • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 6, immagine 1 di 2 Fellowes T7CM On,  Off, Reverse Switch Replacement: passo 6, immagine 2 di 2
      • Remove the plastic switch case.
      • After the plastic case is removed, the switch can be replaced.
      • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
IUPUI, Team 2-2, Baechle Fall 2016 Membro di IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 59
Tutti i Tempi: 4,508
