Salta al contenuto principale
Fellowes T7CM Main Power Cord Replacement
Cosa ti serve
  1. Fellowes T7CM  Main Power Cord Replacement, Fellowes T7CM Casing and Trigger Replacement: passo 1, immagine 1 di 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fellowes T7CM  Main Power Cord Replacement: passo 2, immagine 1 di 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fellowes T7CM  Main Power Cord Replacement: passo 3, immagine 1 di 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fellowes T7CM  Main Power Cord Replacement: passo 4, immagine 1 di 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
    Chiedi a FixBot
    Aggiungi Commento
  5. Fellowes T7CM  Main Power Cord Replacement, Main Power Cord: passo 5, immagine 1 di 2 Fellowes T7CM  Main Power Cord Replacement, Main Power Cord: passo 5, immagine 2 di 2
    • Remove the wire holder. This is a small screwed in piece of plastic which holds the wires in place. The screw length is 10 mm and the head diameter is 6 mm.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fellowes T7CM  Main Power Cord Replacement: passo 6, immagine 1 di 1
    • Remove the blade housing from the external case.
    • Remove the three screws from the blade housing. The screw length is 18 mm and the head diameter is 5 mm
    Chiedi a FixBot
    Aggiungi Commento
  7. Fellowes T7CM  Main Power Cord Replacement: passo 7, immagine 1 di 1
    • Use Caution when lifting the blade housing from the casing.
    • Warning: Sharp Objects are now exposed.
    • Place the blade housing close to the case to ensure no damage occurs to the connected wires and that they remained attached to the casing.
    Chiedi a FixBot
    Aggiungi Commento
  8. Fellowes T7CM  Main Power Cord Replacement: passo 8, immagine 1 di 1
    • Locate the main power cord.
    • Clip the wire and strip the remaining end of the wire. Twist the new cord together with the remaining old wire.
    • Use electrical tape in order to cover the wire splice.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
IUPUI, Team 2-2, Baechle Fall 2016 Membro di IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Membri
16 guide realizzate
1Commento della guida
Great instructions. Only question is what type of cord/plug to purchase? If found this on Amazon, but not sure if it’s correct.
GE 4306-31W5, Black, Household, DIY Repair, Replacement Plug Fix, Ideal for Lamps, TVs and Small Appliances, Indoor Rated, UL Listed, 54268,
https://www.amazon.com/Jasco-Products-54...
bishop5 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 39
Tutti i Tempi: 2,582
