Salta al contenuto principale
Fairphone 4 Rear Cameras Replacement
Cosa ti serve
  1. Fairphone 4 Rear Cameras Replacement, Pry the back cover up: passo 1, immagine 1 di 2 Fairphone 4 Rear Cameras Replacement, Pry the back cover up: passo 1, immagine 2 di 2
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Rear Cameras Replacement: passo 2, immagine 1 di 3 Fairphone 4 Rear Cameras Replacement: passo 2, immagine 2 di 3 Fairphone 4 Rear Cameras Replacement: passo 2, immagine 3 di 3
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Rear Cameras Replacement: passo 3, immagine 1 di 3 Fairphone 4 Rear Cameras Replacement: passo 3, immagine 2 di 3 Fairphone 4 Rear Cameras Replacement: passo 3, immagine 3 di 3
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Rear Cameras Replacement: passo 4, immagine 1 di 3 Fairphone 4 Rear Cameras Replacement: passo 4, immagine 2 di 3 Fairphone 4 Rear Cameras Replacement: passo 4, immagine 3 di 3
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Rear Cameras Replacement, Lever up the Battery: passo 5, immagine 1 di 3 Fairphone 4 Rear Cameras Replacement, Lever up the Battery: passo 5, immagine 2 di 3 Fairphone 4 Rear Cameras Replacement, Lever up the Battery: passo 5, immagine 3 di 3
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Rear Cameras Replacement, Unscrew the cable cover: passo 6, immagine 1 di 1
    • Remove the 4.8 mm-long Phillips screw.
  7. Fairphone 4 Rear Cameras Replacement, Remove the cable cover: passo 7, immagine 1 di 2 Fairphone 4 Rear Cameras Replacement, Remove the cable cover: passo 7, immagine 2 di 2
    • Insert an opening pick beneath the cover near the triangular mark.
    • Twist the opening pick to pry the cover up.
    • Remove the cover.
  8. Fairphone 4 Rear Cameras Replacement, Disconnect cables: passo 8, immagine 1 di 3 Fairphone 4 Rear Cameras Replacement, Disconnect cables: passo 8, immagine 2 di 3 Fairphone 4 Rear Cameras Replacement, Disconnect cables: passo 8, immagine 3 di 3
    • Use a spudger or an opening pick to pry up and disconnect the two camera connection cables.
  9. Fairphone 4 Rear Cameras Replacement: passo 9, immagine 1 di 3 Fairphone 4 Rear Cameras Replacement: passo 9, immagine 2 di 3 Fairphone 4 Rear Cameras Replacement: passo 9, immagine 3 di 3
    • Lift up the right connector to reveal the additional connector beneath it.
    • Use a spudger or an opening pick to pry up and disconnect the third camera connection cable.
  10. Fairphone 4 Rear Cameras Replacement, Unscrew the rear camera module: passo 10, immagine 1 di 1
    • Remove the five 4.8 mm-long Phillips screws.
  11. Fairphone 4 Rear Cameras Replacement: passo 11, immagine 1 di 3 Fairphone 4 Rear Cameras Replacement: passo 11, immagine 2 di 3 Fairphone 4 Rear Cameras Replacement: passo 11, immagine 3 di 3
    • Use an opening pick to slide underneath the rear camera module.
    • Slide the opening pick along the rear camera module to release the clips that hold it in place.
  12. Fairphone 4 Rear Cameras Replacement: passo 12, immagine 1 di 1
    • Lift the rear camera module and remove it.
Conclusione
iFixit Membro di iFixit
Staff
123 Membri
23.922 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 65
Tutti i Tempi: 2,434
