Salta al contenuto principale
ExoPC Slate Battery Replacement
Cosa ti serve
  1. ExoPC Slate Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
    Chiedi a FixBot
    Aggiungi Commento
  2. ExoPC Slate Battery Replacement: passo 2, immagine 1 di 2 ExoPC Slate Battery Replacement: passo 2, immagine 2 di 2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
    Chiedi a FixBot
    Aggiungi Commento
  3. ExoPC Slate Battery Replacement: passo 3, immagine 1 di 3 ExoPC Slate Battery Replacement: passo 3, immagine 2 di 3 ExoPC Slate Battery Replacement: passo 3, immagine 3 di 3
    • Remove the tape covering the metal shield as shown in the image.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
    Chiedi a FixBot
    Aggiungi Commento
  4. ExoPC Slate Battery Replacement: passo 4, immagine 1 di 1
    • Remove tape from the side of the battery.
    • Disconnect the battery from the motherboard.
    • Gently remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Aaron Moore
Membro da: 10/30/18
217 Reputazione
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 41
Tutti i Tempi: 861
