Introduzione
If the buttons on your Evercade EXP are sticking, unresponsive, or worn down, use this guide to safely remove and access them for cleaning or replacement.
The buttons are essential for gameplay, translating your inputs into on-screen actions. Over time, dust, debris, or general wear can affect the overall performance.
Before beginning the repair, inspect the buttons and surrounding shell for visible damage that may affect how the buttons sit in place or how the device opens, as this could make disassembly more challenging.
Power the device off completely and ensure it is disconnected from any power source before starting.
Cosa ti serve
Lay the device on a flat surface, with the screen facing the sufrace.
Using angled tweezers, remove the six rubber screw covers from the sockets.
Flip the device so the screen is facing you.
Four hidden retaining clips hold the pieces together even near each corner of the screen.
Insert a Jimmy into the seam located between the faceplate and the shell.
Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
Repeat until for each of the four clasps to fully release the faceplate from the shell.
Locate the four circular buttons in a diamond shape on the face plate, the two circular buttons placed next to each other, and the two small oval buttons and a circular button in a row near those in a diamond pattern.
Using angled tweezer, gently remove the buttons from the face plate. The buttons may fall out, so be ready to catch any that fall from the device before intended removal.
