Salta al contenuto principale
Eureka 1660SP External Start Switch Realignment
Cosa ti serve
    1. Eureka 1660SP External Start Switch Realignment, Motor Housing: passo 1, immagine 1 di 2 Eureka 1660SP External Start Switch Realignment, Motor Housing: passo 1, immagine 2 di 2
      • Before you start, make sure your vacuum is unplugged the power outlet.
      • Press and hold down the black button below the handle while pulling the pole out.
      Chiedi a FixBot
      Aggiungi Commento
    2. Eureka 1660SP External Start Switch Realignment: passo 2, immagine 1 di 2 Eureka 1660SP External Start Switch Realignment: passo 2, immagine 2 di 2
      • Press the black separator switch to separate the top and bottom halves of the vacuum.
      Chiedi a FixBot
      Aggiungi Commento
    3. Eureka 1660SP External Start Switch Realignment: passo 3, immagine 1 di 3 Eureka 1660SP External Start Switch Realignment: passo 3, immagine 2 di 3 Eureka 1660SP External Start Switch Realignment: passo 3, immagine 3 di 3
      • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
      • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
      • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
      Chiedi a FixBot
      Aggiungi Commento
    1. Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: passo 4, immagine 1 di 3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: passo 4, immagine 2 di 3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: passo 4, immagine 3 di 3
      • If the external switch is slightly misaligned as shown, realign it with the internal switch.
      • Make sure the spring loaded button on the underside of the housing is intact when reassembling the motor housing. It is prone to eject when opening the motor housing.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Evan Fodi
Membro da: 09/24/13
122 Reputazione
2 guide realizzate
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Membro di UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Membri
30 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 21
Tutti i Tempi: 2,784
