Introduzione
This guide is for the Euhomy IM-06D icemaker. This guides purpose is to replace the compressor relay. This part helps create the ice along with the compressor itself. Some symptoms that mean this part may need to be replaced are if the machine is not making ice and is otherwise working as intended. If this is the case, then the compressor relay may need to be replaced. Please make sure to unplug the device before starting all guides.
Cosa ti serve
Rotate the device so that the screws on the bottom are visible.
Remove the two 15 mm Phillips screws.
Remove the two 10 mm Phillips screws.
Locate the black box under the green ground cable and find the silver clip running across the back of it.
Use a pry tool remove the clip.
Remove the box.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
