Salta al contenuto principale
Epson VS250 Lamp Replacement
Cosa ti serve
  1. Epson VS250 Lamp Replacement, Lamp: passo 1, immagine 1 di 1
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Use Phillips #1 screwdriver to loosen the 10 mm screw on the top right corner of the projector.
    • The screw does not need to come all the way out.
    Chiedi a FixBot
    Aggiungi Commento
  2. Epson VS250 Lamp Replacement: passo 2, immagine 1 di 1
    • Slide the cover to the right and lift the cover up and out to remove.
    Chiedi a FixBot
    Aggiungi Commento
  3. Epson VS250 Lamp Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to loosen the two 10 mm screws that hold the lamp in place.
    • The two 10 mm screws do not need to come all the way out. Just ensure they are loose.
    Chiedi a FixBot
    Aggiungi Commento
  4. Epson VS250 Lamp Replacement: passo 4, immagine 1 di 2 Epson VS250 Lamp Replacement: passo 4, immagine 2 di 2
    • After loosening both screws, remove the lamp from the projector by pulling it up and out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Clemson, Team 4-2, Hunter Fall 2021 Membro di Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 20
Tutti i Tempi: 908
