Salta al contenuto principale
Epson VS250 Air Filter Replacement
    1. Epson VS250 Air Filter  Replacement, Air Filter: passo 1, immagine 1 di 1
      • The cover for the air filter can be located at the top left corner of the projector when positioned so that the word "Epson" is facing you.
      • Place your fingers underneath the indented area of the center portion of the filter cover.
      • Once your fingers are aligned simply grip it and pull up to remove.
      Chiedi a FixBot
      Aggiungi Commento
    2. Epson VS250 Air Filter  Replacement: passo 2, immagine 1 di 1
      • Grip the black tab and pull it directly up to remove the air filter from the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Clemson, Team 4-2, Hunter Fall 2021 Membro di Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Membri
17 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 11
Ultimi 30 giorni: 25
Tutti i Tempi: 544
